David,
"... queueRequest Priority 1 not lockholder...",
The messages you are seeing are normal, they do not indicate an error. I think we should change the messages so that they look less like errors.
Here is the output of a serial device that is working normally, with all asynTrace flags set to 1.
2007/03/28 19:54:24.184 serial1 addr -1 queueRequest priority 0 not lockHolder
2007/03/28 19:54:24.184 serial1 schedule queueRequest timeout
2007/03/28 19:54:24.184 serial1 callback
2007/03/28 19:54:24.184 13BMA:ip1_serial: asynCallbackProcess, state=3
2007/03/28 19:54:24.217 serial1 flush2007/03/28 19:54:24.267 serial1 flush
2007/03/28 19:54:24.300 13BMA:ip1_serial flush
2007/03/28 19:54:24.350 serial1 write.
2007/03/28 19:54:24.384 serial1 write 3 RD\r
2007/03/28 19:54:24.434 serial1 write RD\r
2007/03/28 19:54:24.467 13BMA:ip1_serial: nwrite=2, status=0, nawt=2, data=RD
2007/03/28 19:54:24.550 serial1 read.
2007/03/28 19:54:24.600 serial1 read 36 RD\023\n\r19 09:38 5400V 8.2E-5I H---23\n\r
2007/03/28 19:54:24.684 serial1 read RD\023\n\r19 09:38 5400V 8.2E-5I H---23\n\r
2007/03/28 19:54:24.767 serial1 read.
2007/03/28 19:54:24.867 serial1 read 1 \021
2007/03/28 19:54:24.867 serial1 read \021
2007/03/28 19:54:24.900 13BMA:ip1_serial: inlen=40, status=0, ninp=37, data=RD\023\n\r19 09:38 5400V 8.2E-5I H---23\n\r\021
2007/03/28 19:54:25.034 13BMA:ip1_serial: inlen=37, nbytesTransfered=37, ntranslate=47
By the way, you said you are working on a Modbus driver. Is this serial, or Modbus TCP? I am just about to release a package for Modbus TCP that uses asyn for the TCP I/O, and asyyn device support. I hope to release it by thee end of the week. I'l send a note to tech-talk when its ready.
Sent: Wed 3/28/2007 2:29 PM
To: [email protected]
Subject: ASYN Octet driver question
I'm trying to solve a problem with the ASYN Octet package in my Modbus
driver. When I have tracing turned on, I get exceptions every time I
try to write or read something, that say "... queueRequest Priority 1
not lockholder...", and then "...queueRequest timeout...".
However, the requests still get processed (most of the time....).
Trying to track down what this "...not lockholder..." message is from.
I look through my code, and I don't see anything where I'm calling the
"asynManager->registerPort" routine, nor do I see anything that
references it. Would that cause this problem?
David Dudley
- ASYN Octet driver question David Dudley
Maximum archival rate Terry Cornall
<2007>
2025
2026
RE: ASYN Octet driver question David Dudley
<2007>
2025
2026
