1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: ASYN Octet driver question
To: <[email protected]>
Date: Thu, 29 Mar 2007 08:18:12 -0500
This is a serial modbus driver.  It supports AI, AAI, AO, AAO, BI, BO,
MBBI, MBBO, StringIn, and StringOut.  I'm going to add Waveform support
to it as well.  Right now, I seem to have an intermittent problem where
it will just start timeing out messages after a while, and I get quite a
few communications failures that I don't think I should have.  I think
it's a problem with the asyn thread communicating callbacks with the
database thread.
David Dudley
>>> "Mark Rivers" <[email protected]> 3/28/2007 9:06 PM >>>
David,
"... queueRequest Priority 1 not lockholder...",
The messages you are seeing are normal, they do not indicate an error.
I think we should change the messages so that they look less like
errors.
Here is the output of a serial device that is working normally, with
all asynTrace flags set to 1.
2007/03/28 19:54:24.184 serial1 addr -1 queueRequest priority 0 not
lockHolder
2007/03/28 19:54:24.184 serial1 schedule queueRequest timeout
2007/03/28 19:54:24.184 serial1 callback
2007/03/28 19:54:24.184 13BMA:ip1_serial: asynCallbackProcess, state=3
2007/03/28 19:54:24.217 serial1 flush2007/03/28 19:54:24.267 serial1
flush
2007/03/28 19:54:24.300 13BMA:ip1_serial flush
2007/03/28 19:54:24.350 serial1 write.
2007/03/28 19:54:24.384 serial1 write 3 RD\r
2007/03/28 19:54:24.434 serial1 write RD\r
2007/03/28 19:54:24.467 13BMA:ip1_serial: nwrite=2, status=0, nawt=2,
data=RD
2007/03/28 19:54:24.550 serial1 read.
2007/03/28 19:54:24.600 serial1 read 36 RD\023\n\r19 09:38 5400V
8.2E-5I H---23\n\r
2007/03/28 19:54:24.684 serial1 read RD\023\n\r19 09:38 5400V 8.2E-5I
H---23\n\r
2007/03/28 19:54:24.767 serial1 read.
2007/03/28 19:54:24.867 serial1 read 1 \021
2007/03/28 19:54:24.867 serial1 read \021
2007/03/28 19:54:24.900 13BMA:ip1_serial: inlen=40, status=0, ninp=37,
data=RD\023\n\r19 09:38 5400V 8.2E-5I H---23\n\r\021
2007/03/28 19:54:25.034 13BMA:ip1_serial: inlen=37,
nbytesTransfered=37, ntranslate=47
By the  way, you said you are working on a Modbus driver.  Is this
serial, or  Modbus TCP?  I am just about to release a package for Modbus
TCP that uses asyn for the TCP I/O, and asyyn device support.  I hope to
release it by  thee end of the week.  I'l send a note to tech-talk when
its ready.
Sent: Wed 3/28/2007 2:29 PM
To: [email protected]
Subject: ASYN Octet driver question
I'm trying to solve a problem with the ASYN Octet package in my Modbus
driver.  When I have tracing turned on, I get exceptions every time I
try to write or read something, that say "... queueRequest Priority 1
not lockholder...", and then "...queueRequest timeout...".
However, the requests still get processed (most of the time....).
Trying to track down what this "...not lockholder..." message is from.
I look through my code, and I don't see anything where I'm calling the
"asynManager->registerPort" routine, nor do I see anything that
references it.  Would that cause this problem?
David Dudley
BEGIN:VCARD
VERSION:2.1
X-GWTYPE:USER
FN:David Dudley
TEL;WORK:880-3740
ORG:;MIS
TEL;PREF;FAX:880-3741
EMAIL;WORK;PREF;NGW:[email protected]
N:Dudley;David
END:VCARD
Prev: WireSet & mpc8540 Korhonen Timo
Next: Re: WireSet & mpc8540 Ernest L. Williams Jr.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: ASYN Octet driver question Mark Rivers
Next: RE: ASYN Octet driver question David Dudley
