1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Proposed change in asyn interruptCallback APIs
Cc: Eric Norum <[email protected]>, tech-talk tech-talk <[email protected]>
Date: Thu, 29 Mar 2007 14:00:50 -0500
Mark Rivers wrote:
I have found a problem in the APIs used by device support to receive callbacks from asynDrivers. These are the callbacks that an asyn driver supports via pasynManager->registerInterruptSource, and device support accesses via, for example, pasynInt32->registerInterruptUser. These callbacks allow EPICS records to have "I/O Intr" record processing, i.e. the record only gets processed when the driver calls back device support with "new" data.
Assuming that the only changes you'd be making to the asyn API would be to the routines mentioned, i.e. pasynManager->registerInterruptSource() and to methods for specific ASYN message types such as asynInt32 (but not to asynOctet) then this should not affect my directNetAsyn layer at all.
If you make any non-trivial changes to asynOctet I'm sure mine would not be the only code affected, but from your description it doesn't appear that this will be necessary.
- Andrew
The right to be heard does not automatically include
the right to be taken seriously. -- Hubert H. Humphrey
Proposed change in asyn interruptCallback APIs Mark Rivers
Prev: Re: .cmd file downloading problem Kate Feng
Next: Re: Maximum archival rate Maren Purves
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Proposed change in asyn interruptCallback APIs Mark Rivers
Next: Obituary for Coles SIbley who worked with our community at MIT Bates and Oak Ridge National Lab Dalesio, Leo `Bob`
