Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020
Subject: Question about mbboDirect record
To: "tech-talk tech-talk" <tech-talk@aps.anl.gov>
Date: Thu, 29 Mar 2007 17:39:34 -0500
Folks,
I have a question about the mbboDirect record, specifically the
interaction of the .VAL and .B0-.BF fields.
On the mbbiDirect record the 	.VAL fields and .BO-.BF fields are
always consistent.
However, this does not seem to be the case with the mbboDirect record.
If I write to the .Bn fields of the mbboDirect record, the .VAL field
updates as expected.  However, the opposite is not true.  If I write to
.VAL field, the .Bn fields do not change.  This does not make sense to
me.
Can someone explain why this is so, or is it a bug?
Re: Question about mbboDirect record Andrew Johnson
Prev: Re: Maximum archival rate Lawrence T. Hoff
Next: RE: WireSet & mpc8540 Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020
Prev: RE: WireSet & mpc8540 Jeff Hill
Next: Re: Question about mbboDirect record Andrew Johnson
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
