1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: WireSet & mpc8540
To: "'Korhonen Timo'" <[email protected]>
Cc: "EPICS-tech-talk" <[email protected]>
Date: Thu, 29 Mar 2007 18:23:44 -0600
Timo,
Please send the output from the following command for all three of the
symbols that are undefined:
c++filtppc _Z7WireSetIsEvRKT.
This "demangles" the c++ symbol. Hopefully, we can determine which of the
overloaded functions are undefined.
A complete rebuild of base, and the application, might also help. Also, make
certain that the same c++ compiler version is used to produce all of the
object code linked into mv3100.munch.
Jeff
> -----Original Message-----
> From: Korhonen Timo [mailto:[email protected]]
> Sent: Thursday, March 29, 2007 7:12 AM
> To: '[email protected] '; 'Williams Jr, Ernest L.'
> Subject: WireSet & mpc8540
> Hello all,
> I have been trying to get EPICS running on a Motorola mv3100 and vxWorks
> 6.2,
> using the newest EPICS release (3.14.9). The build goes smoothly and
> without complaints.
> However, when I build the application and load it, I get a few
> unresolved symbols:
> ld < mv3100.munch
> Warning: module 0x1a16f20 holds reference to undefined symbol
> _Z7WireSetIfEvRKT.
> _Z7WireSetIiEvRKT.
> _Z7WireSetIsEvRKT.
> ld(): error loading file (errno = 0xe0005).
> value = 0 = 0x0
> Trying to trace these back, they seem to come from Channel Access. The
> prototypes
> (WireSet, I believe) are declared in osiWireFormat.h, and the
> implementation, as far
> as I have understood it correctly, are in osdWireFormat.h. I could not
> sort out the ifdefs to
> see why this routine is not linked in, or what the problem actually is.
> I ran out of ideas. Can somebody help me further?
> Timo
> Timo Korhonen  PSI (Paul Scherrer Institut, http://www.psi.ch)
>                CH-5232 Villigen PSI
>                tel + 41- 56 3103262  fax + 41 - 56 310 3383
> e-mail:	       [email protected]
WireSet & mpc8540 Korhonen Timo
Prev: Question about mbboDirect record Mark Rivers
Next: NSLS Controls Computing Leader Position Zitvogel, Emil
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: WireSet & mpc8540 Ernest L. Williams Jr.
Next: Question about mbboDirect record Mark Rivers
