1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: sequencer installation
To: Janet Anderson <[email protected]>
Cc: Eric Norum <[email protected]>, [email protected]
Date: Mon, 02 Apr 2007 19:24:00 -0700
Thank you Janet.
I understand that the %c:%.stt  target needs to be included in the
RULES. This can be done by either editing the ioc Makefile ( as
described below) or editing the EPICS_BASE config(ure?) files.
But I do not want to edit the EPICS_BASE/config(ure) files so I can
easily reinstall epics or duplicate my installation. So to change the
SNCSEQ build variable, I use
export SNCSEQ=/path/to/seq
and then build epics with make -e (environment has precedence on make
variables). This works great.
1/
Obviously I cannot use the same trick to include a file in a makefile
unless the inclusion is function of a make variable.
2/
Now I am building synApps. And for the same reason as with EPICS_BASE, I
do not want to change any Makefile. Unfortunately all of the build that
includes the sequencer (stt, st files) breaks. Of course, there is now
rules to build C files from the stt/st ones.
Does that mean that now I have no choice but to edit one of my
Makefiles?
Shouldn't the EPICS_BASE build system be smart enough to to include a
rule for stt files based on the setting of SNCSEQ?
Any input is appreciated....
Emmanuel
On Mon, 2006-10-09 at 11:08 -0500, Janet Anderson wrote:
> If a configure/RULES_BUILD file exists in a support module defined
> in an application's RELEASE file it will be included by Makefiles
> during the build. This allows a support module to create module
> specific build rules to be used by ioc applications which use the
> support module.
> When a make is done in the configure directory of a makeBaseApp.pl
> application a RULES_INCLUDE file is created in each O.<arch>
> subdirectory. This file contains an include line for a RULES_BUILD
> file from each support module defined in the configure/RELEASE file
> (except EPICS_BASE). The created RULES_INCLUDE file will be included
> by EPICS_BASE configure files during the build.
> Janet
> Eric Norum wrote:
> > I'm sure that Janet can provide a better explanation of this, but the
> > sequencer seems to work fine for me without requiring any manual
> > additions to the RULES_BUILD file.  I have only to add a definition for
> > SNCSEQ in the configure/RELEASE file:
> > SNCSEQ=/usr/local/iocapps/R3.14.8.2/modules/soft/seq/2-0-11-asd2
> > On Oct 6, 2006, at 8:00 PM, Emmanuel Mayssat wrote:
> >> Mark,
> >> I also need to include the RULES_BUILD file that comes with the
> >> sequencer source to be able to build the C files from the st one.
> >> MyIoc_SRCS=sequencer.st
> >> include ${EPICS_SEQUENCER_TOP_DIR}/configure/RULES_BUILD
> >> Emmanuel
> > Eric Norum <[email protected] <mailto:[email protected]>>
> > Advanced Photon Source
> > Argonne National Laboratory
> > (630) 252-4793
Prev: Re: CALC record weird behaviour Dirk Zimoch
Next: RE: OMS MAXv reset/power-up problem Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: NSLS Controls Computing Leader Position Zitvogel, Emil
Next: firewire video on RTEMS-4.6.x-MVME5500 Kate Feng
