Unfortunately, that didn't work.
In vdct, I can set the .VAL field to 1, but when I load the db, the VAL
field is 0. Setting DOL to 1 causes it to have a 'CONSTANT 1' value
when you do a 'dbpr' on the field, and I have OMSL set to 'closed-loop',
however the .VAL field remains at 0. If I do a forward link to the
block, it outputs a zero, and the .VAL remains 0. If a do a 'dbpf' to
set the value to 1, it then works fine. What I did as a patch around
the questionable action was to use a BI block with its DTYPE set to
'Soft Channel' and an INP of '1' that is linked to the BO, but seems
like a round-about way of doing such a simple thing.
I thought I was probably just missing something on the BO block.
David Dudley
"Paul Sichta" <[email protected]> 4/4/2007 9:20 AM >>>
David,
Can you set the DOL to '1' and use closed-loop control, rather than
the
default supervisory.
BEGIN:VCARD
VERSION:2.1
X-GWTYPE:USER
FN:David Dudley
TEL;WORK:880-3740
ORG:;MIS
TEL;PREF;FAX:880-3741
EMAIL;WORK;PREF;NGW:[email protected]
N:Dudley;David
END:VCARD
