1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Outputting a constant value
To: <[email protected]>
Date: Wed, 04 Apr 2007 09:44:42 -0500
Unfortunately, that didn't work.
In vdct, I can set the .VAL field to 1, but when I load the db, the VAL
field is 0.  Setting DOL to 1 causes it to have a 'CONSTANT 1' value
when you do a 'dbpr' on the field, and I have OMSL set to 'closed-loop',
however the .VAL field remains at 0.  If I do a forward link to the
block, it outputs a zero, and the .VAL remains 0.  If a do a 'dbpf' to
set the value to 1, it then works fine.  What I did as a patch around
the questionable action was to use a BI block with its DTYPE set to
'Soft Channel' and an INP of '1' that is linked to the BO, but seems
like a round-about way of doing such a simple thing.
I thought I was probably just missing something on the BO block.
David Dudley
>>> "Paul Sichta" <[email protected]> 4/4/2007 9:20 AM >>>
David,
Can you set the DOL to '1' and use closed-loop control, rather than
the
default supervisory.
Paul Sichta
Princeton Plasma Physics Laboratory
609-243-3477
-----Original Message-----
Sent: Wednesday, April 04, 2007 10:00 AM
To: [email protected]
Subject: Outputting a constant value
I have a BO where every time I trigger it, I want to output a constant
value.  Since the .VAL field can't be set to a constant through vdct,
is
there an easy way to force it to have a '1' value all the time?
David Dudley
BEGIN:VCARD
VERSION:2.1
X-GWTYPE:USER
FN:David Dudley
TEL;WORK:880-3740
ORG:;MIS
TEL;PREF;FAX:880-3741
EMAIL;WORK;PREF;NGW:[email protected]
N:Dudley;David
END:VCARD
Re: Outputting a constant value Ned D. Arnold
Re: Outputting a constant value Tim Mooney
Prev: RE: Outputting a constant value David Dudley
Next: Re: Outputting a constant value Ned D. Arnold
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
