1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Motor Record - OMS58 Driver
To: Ralph Lange <[email protected]>
Date: Fri, 13 Apr 2007 09:39:49 -0500
Ralph,
If you look at the "Known Problems" from R5-4 to R5-9 on the motor
record web page;
http://www.aps.anl.gov/upd/people/sluiter/epics/motor/index.html
you will find the following;
   1. An undocumented change was made in R5-4 to two OMS setup
      functions. Namely, the unused 2nd argument ("axes per card") was
      eliminated from omsSetup() and oms58Setup().
In other words, the 2nd argument was eliminated. That is probably your problem.
Ron
Ralph Lange wrote:
Hi -
I'm moving a stepper motor application using an OMS VME58 card:
  from EPICS 3.13.9 / motor 4.9.3   to   EPICS 3.14.8.2 / motor 6.1
In the old setup everything works fine, in the new setup the driver claims that it doesn't find the VME58 motor card. Hardware settings are unchanged, the setup call in the st.cmd is the same.
Searching the release notes of the motor record I did not find anything that I found applicable to my problem.
Before I dig into the code: Is there anything obvious that I didn't see? Similar effects somewhere?
HW: vxWorks 5.4.2, mv2100, OMS VME58, test stand with no other VME cards.
Thanks a lot!
Ralph
RE: Motor Record - OMS58 Driver Gillingham, IJ (Ian)
Motor Record - OMS58 Driver Ralph Lange
Prev: Re: Motor Record - OMS58 Driver Martin L. Smith
Next: RE: Motor Record - OMS58 Driver Gillingham, IJ (Ian)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
