Subject: |
RE: Motor Record - OMS58 Driver |
"Gillingham, IJ \(Ian\)" <[email protected]> |
To: |
"EPICS Tech Talk" <[email protected]> |
Date: |
Mon, 16 Apr 2007 08:44:15 +0100 |
This is the very same issue I experienced when migrating my application
from R3.13.9 to R3.14. I concur with Ron about the undocumented change
in parameters. On dropping the 'Number of axes' parameter, it all sprang
into life! It took me a couple of days to track it down.
Ian
-----Original Message-----
Sent: 13 April 2007 15:40
To: Ralph Lange
Cc: EPICS Tech Talk
Subject: Re: Motor Record - OMS58 Driver
Ralph,
If you look at the "Known Problems" from R5-4 to R5-9 on the motor
record web page;
http://www.aps.anl.gov/upd/people/sluiter/epics/motor/index.html
you will find the following;
> 1. An undocumented change was made in R5-4 to two OMS setup
> functions. Namely, the unused 2nd argument ("axes per card") was
> eliminated from omsSetup() and oms58Setup().
In other words, the 2nd argument was eliminated. That is probably your
problem.
Ron
Ralph Lange wrote:
> Hi -
> I'm moving a stepper motor application using an OMS VME58 card:
> from EPICS 3.13.9 / motor 4.9.3 to EPICS 3.14.8.2 / motor 6.1
> In the old setup everything works fine, in the new setup the driver
> claims that it doesn't find the VME58 motor card. Hardware settings
> are unchanged, the setup call in the st.cmd is the same.
> Searching the release notes of the motor record I did not find
> anything that I found applicable to my problem.
> Before I dig into the code: Is there anything obvious that I didn't
> see? Similar effects somewhere?
> HW: vxWorks 5.4.2, mv2100, OMS VME58, test stand with no other VME
cards.
> Thanks a lot!
> Ralph
- Re: Motor Record - OMS58 Driver Ralph Lange
- Re: Motor Record - OMS58 Driver Ronald L. Sluiter
<2007>
2025
2026
<2007>
2025
2026
