1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Motor Record - OMS58 Driver
To: EPICS Tech Talk <[email protected]>
Date: Mon, 16 Apr 2007 10:30:39 +0200
Thanks a lot!
Of course this was the rootlet of evil.
I was only looking in the release notes - not in the list of known problems.
Cheers,
Ralph
Gillingham, IJ (Ian) wrote:
This is the very same issue I experienced when migrating my application
from R3.13.9 to R3.14. I concur with Ron about the undocumented change
in parameters. On dropping the 'Number of axes' parameter, it all sprang
into life! It took me a couple of days to track it down.
Ian
-----Original Message-----
From: Ronald L. Sluiter [mailto:[email protected]] Sent: 13 April 2007 15:40
To: Ralph Lange
Cc: EPICS Tech Talk
Ralph,
If you look at the "Known Problems" from R5-4 to R5-9 on the motor
record web page;
http://www.aps.anl.gov/upd/people/sluiter/epics/motor/index.html
you will find the following;
   1. An undocumented change was made in R5-4 to two OMS setup
      functions. Namely, the unused 2nd argument ("axes per card") was
      eliminated from omsSetup() and oms58Setup().
In other words, the 2nd argument was eliminated. That is probably your problem.
Ron
RE: Motor Record - OMS58 Driver Gillingham, IJ (Ian)
Prev: RE: Motor Record - OMS58 Driver Gillingham, IJ (Ian)
Next: Re: epics compiling problem Kate Feng
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Building asyn4-7 with epics-3.14.8 under win32-x86-cygwin White, Glen Russell
