1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Building asyn4-7 with epics-3.14.8 under win32-x86-cygwin
To: "Andrew Johnson" <[email protected]>, "White, Glen Russell" <[email protected]>
Cc: <[email protected]>
Date: Mon, 16 Apr 2007 18:35:28 -0500
Glen,
I have not had that problem.  But I notice that you are building the for
win32-x86-cygwin architecture, while I am building for cygwin-x86.  What
is the difference between those?  I doubt if that is the problem, but I
have never built that architecture.
> -----Original Message-----
> From: Andrew Johnson [mailto:[email protected]]
> Sent: Monday, April 16, 2007 5:02 PM
> To: White, Glen Russell
> Cc: [email protected]
> Subject: Re: Building asyn4-7 with epics-3.14.8 under win32-x86-cygwin
> Hi Glen,
> White, Glen Russell wrote:
> > I tried running make after dos2unix on asynRecord.dbd (and
> again with
> > unix2dos), I get the same error message either way, so I guess it
> > isn't a LF character problem?
> That would seem to imply not, but I'm not completely sure.  There's
> something different between your asynRecord.dbd file and the other
> *Record.dbd files in your base installation, since they all pass the
> exact same syntax to dbToRecordtypeH.exe.  Unfortunately I'm not a
> Windows person, so I'm not the best person to chase this down.  Any
> other cygwin users out there with an idea?
> >>/cygdrive/c/epics-3.14.8/base/bin/win32-x86-cygwin/dbToRecordt
> >>ypeH.exe  -I . -I .. -I ../../dbd -I
> >>/cygdrive/c/epics-3.14.8/base/dbd
> >>../../asyn/asynRecord/asynRecord.dbd ../O.Common/asynRecord.h
> >>>Error   Last token ""dbCommon.dbd""
> >>>input line:     include "dbCommon.dbd"
> >>>   in: file ../../asyn/asynRecord/asynRecord.dbd line 107
> >>>db_parse returned -1
> >>>Terminal error For input file ../../asyn/asynRecord/asynRecord.dbd
> - Andrew
> The right to be heard does not automatically include
> the right to be taken seriously. -- Hubert H. Humphrey
RE: Building asyn4-7 with epics-3.14.8 under win32-x86-cygwin White, Glen Russell
Re: Building asyn4-7 with epics-3.14.8 under win32-x86-cygwin Andrew Johnson
Prev: Re: Building asyn4-7 with epics-3.14.8 under win32-x86-cygwin Andrew Johnson
Next: RE: Building asyn4-7 with epics-3.14.8 under win32-x86-cygwin White, Glen Russell
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
