1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Building asyn4-7 with epics-3.14.8 under win32-x86-cygwin
To: "Mark Rivers" <[email protected]>, "Andrew Johnson" <[email protected]>
Cc: <[email protected]>
Date: Mon, 16 Apr 2007 17:10:42 -0700
I don't know what the differnce between the two is, but it solved the problem! I rebuilt everything using cygwin-x86 and had no problems (not sure even where I got win32-x86-cygwin from, I think from a list in one of the base config files ).
Thanks!
Glen.
> -----Original Message-----
> From: Mark Rivers [mailto:[email protected]]
> Sent: Monday, April 16, 2007 4:35 PM
> To: Andrew Johnson; White, Glen Russell
> Cc: [email protected]
> Glen,
> I have not had that problem.  But I notice that you are
> building the for win32-x86-cygwin architecture, while I am
> building for cygwin-x86.  What is the difference between
> those?  I doubt if that is the problem, but I have never
> built that architecture.
> Mark
> > From: Andrew Johnson [mailto:[email protected]]
> > Sent: Monday, April 16, 2007 5:02 PM
> > To: White, Glen Russell
> > Subject: Re: Building asyn4-7 with epics-3.14.8 under
> win32-x86-cygwin
> > Hi Glen,
> > White, Glen Russell wrote:
> > > I tried running make after dos2unix on asynRecord.dbd (and
> > again with
> > > unix2dos), I get the same error message either way, so I guess it
> > > isn't a LF character problem?
> > That would seem to imply not, but I'm not completely sure.  There's
> > something different between your asynRecord.dbd file and the other
> > *Record.dbd files in your base installation, since they all
> pass the
> > exact same syntax to dbToRecordtypeH.exe.  Unfortunately I'm not a
> > Windows person, so I'm not the best person to chase this down.  Any
> > other cygwin users out there with an idea?
> > >>/cygdrive/c/epics-3.14.8/base/bin/win32-x86-cygwin/dbToRecordt
> > >>ypeH.exe  -I . -I .. -I ../../dbd -I
> > >>/cygdrive/c/epics-3.14.8/base/dbd
> > >>../../asyn/asynRecord/asynRecord.dbd ../O.Common/asynRecord.h
> > >>>Error   Last token ""dbCommon.dbd""
> > >>>input line:     include "dbCommon.dbd"
> > >>>   in: file ../../asyn/asynRecord/asynRecord.dbd line 107
> > >>>db_parse returned -1
> > >>>Terminal error For input file
> > - Andrew
> > The right to be heard does not automatically include the
> right to be
> > taken seriously. -- Hubert H. Humphrey
RE: Building asyn4-7 with epics-3.14.8 under win32-x86-cygwin Jeff Hill
Re: Building asyn4-7 with epics-3.14.8 under win32-x86-cygwin Andrew Johnson
RE: Building asyn4-7 with epics-3.14.8 under win32-x86-cygwin Mark Rivers
Prev: RE: Building asyn4-7 with epics-3.14.8 under win32-x86-cygwin Mark Rivers
Next: RE: Building asyn4-7 with epics-3.14.8 under win32-x86-cygwin Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
