FWIW:
The difference between cygwin-x86 and win32-x86-cygwin is the OS that EPICS
is interfaced to.
win32-x86 (native win32 OS, x86, M$ compiler)
win32-x86-cygwin (native win32 OS, x86, cygwin gnu compiler)
win32-x86-borland (native win32 OS, x86, borland compiler)
cygwin-x86 (cygwin POSIX emulation OS, x86, cygwin gcc compiler)
Last time I ran performance tests I observed that EPICS based on cygwin-x86
POSIX emulation on windows was substantially less efficient than EPICS based
on native win32-x86 on windows. Also, depending on how cygwin POSIX
emulation was implemented time stamps might be less precise on cygwin-x86
(this could be investigated by running epicsTimeTestHost on both versions).
Jeff
> -----Original Message-----
> From: White, Glen Russell [mailto:[email protected]]
> Sent: Monday, April 16, 2007 6:11 PM
> To: Mark Rivers; Andrew Johnson
> Cc: [email protected]
> Subject: RE: Building asyn4-7 with epics-3.14.8 under win32-x86-cygwin
> I don't know what the differnce between the two is, but it solved the
> problem! I rebuilt everything using cygwin-x86 and had no problems (not
> sure even where I got win32-x86-cygwin from, I think from a list in one of
> the base config files ).
> Thanks!
> Glen.
> > From: Mark Rivers [mailto:[email protected]]
> > Sent: Monday, April 16, 2007 4:35 PM
> > To: Andrew Johnson; White, Glen Russell
> > Glen,
> > I have not had that problem. But I notice that you are
> > building the for win32-x86-cygwin architecture, while I am
> > building for cygwin-x86. What is the difference between
> > those? I doubt if that is the problem, but I have never
> > built that architecture.
> > Mark
> > > From: Andrew Johnson [mailto:[email protected]]
> > > Sent: Monday, April 16, 2007 5:02 PM
> > > To: White, Glen Russell
> > > Subject: Re: Building asyn4-7 with epics-3.14.8 under
> > win32-x86-cygwin
> > > Hi Glen,
> > > White, Glen Russell wrote:
> > > > I tried running make after dos2unix on asynRecord.dbd (and
> > > again with
> > > > unix2dos), I get the same error message either way, so I guess it
> > > > isn't a LF character problem?
> > > That would seem to imply not, but I'm not completely sure. There's
> > > something different between your asynRecord.dbd file and the other
> > > *Record.dbd files in your base installation, since they all
> > pass the
> > > exact same syntax to dbToRecordtypeH.exe. Unfortunately I'm not a
> > > Windows person, so I'm not the best person to chase this down. Any
> > > other cygwin users out there with an idea?
> > > >>/cygdrive/c/epics-3.14.8/base/bin/win32-x86-cygwin/dbToRecordt
> > > >>ypeH.exe -I . -I .. -I ../../dbd -I
> > > >>/cygdrive/c/epics-3.14.8/base/dbd
> > > >>../../asyn/asynRecord/asynRecord.dbd ../O.Common/asynRecord.h
> > > >>>Error Last token ""dbCommon.dbd""
> > > >>>input line: include "dbCommon.dbd"
> > > >>> in: file ../../asyn/asynRecord/asynRecord.dbd line 107
> > > >>>db_parse returned -1
> > > >>>Terminal error For input file
> > > - Andrew
> > > The right to be heard does not automatically include the
> > right to be
> > > taken seriously. -- Hubert H. Humphrey
- Re: Building asyn4-7 with epics-3.14.8 under win32-x86-cygwin Andrew Johnson
- RE: Building asyn4-7 with epics-3.14.8 under win32-x86-cygwin Mark Rivers
- RE: Building asyn4-7 with epics-3.14.8 under win32-x86-cygwin White, Glen Russell
Kepco BIT 4886 Shepherd, EL (Emma)
<2007>
2025
2026
<2007>
2025
2026
