1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: channel access security deadlock from asInit()
To: "Ned D. Arnold" <[email protected]>
Cc: Kay-Uwe Kasemir <[email protected]>, tech talk <[email protected]>
Date: Wed, 18 Apr 2007 19:18:26 +0200
Ned -
I thought about this, too ... and I would completely understand if the CA server does not grant access (neither read nor write) to any channels in that case.
But actually it doesn't even resolve the names anymore, which is a different thing, misleading, and probably neither appropriate nor intended.
Ralph
Ned D. Arnold wrote:
Ralph -
I think the behavior that you observed is by design ... if one tries to specify a configuration file that does not exist, it means you intended to have *some* access control in place. If the file doesn't exist, this is a fatal error and the safest thing to do is not allow any access at all so someone will fix the problem immediately.
I actually remember this discussion with Marty Kraimer about 16 years ago ...
Ned
channel access security deadlock from asInit() Kay-Uwe Kasemir
Re: channel access security deadlock from asInit() Ralph Lange
Re: channel access security deadlock from asInit() Ned D. Arnold
Prev: Re: channel access security deadlock from asInit() Ned D. Arnold
Next: Re: channel access security deadlock from asInit() Kay-Uwe Kasemir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
