1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Firewire (IEEE1394) Camera driver - errors in st.cmd file
To: "Margaret Smith" <[email protected]>, <[email protected]>
Date: Thu, 19 Apr 2007 17:26:43 -0500
Those commands (set_savefile_path, etc) are commands for the autosave facility in EPICS.  It appears that you have those commands in your st.cmd file, but you did not build the application with that module included.
Sent: Thursday, April 19, 2007 5:14 PM
To: [email protected]
Subject: Firewire (IEEE1394) Camera driver - errors in st.cmd file
Hi
Anyone understand these error msgs. I've got the Firewire camera driver and medm screen provided by SLS (from webpage http://epics.web.psi.ch/software/firewire/) running, but I get some error messages in the st.cmd file as follows:
st.cmd -- Line 18 -- Command save_restoreSet_Debug not found.
st.cmd -- Line 19 -- Command set_requestfile_path not found.
st.cmd -- Line 20 -- Command set_savefile_path not found.
st.cmd -- Line 21 -- Command save_restoreSet_status_prefix not found.
st.cmd -- Line 22 -- Command set_pass0_restoreFile not found.
st.cmd -- Line 23 -- Command set_pass1_restoreFile not found.
st.cmd -- Line 29 -- Command create_monitor_set not found.
I've also attached the entire st.cmd file and the output when I run (st.cmd.out1).
I've got an inkling of what they, but don't know where they are. I could just remove these but may miss a feature that I want.
Thx,
Margaret
Margaret Smith
Systems Analyst
Canadian Light Source
Phone (306) 657-3580
Fax (306) 657-3535
Firewire (IEEE1394) Camera driver - errors in st.cmd file Margaret Smith
Prev: Firewire (IEEE1394) Camera driver - errors in st.cmd file Margaret Smith
Next: RE: Strange channel access problem Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: linux with 2.6 kernel Geoff Savage
