Mark,
> - ezca doesn't connect
> - The command line "caget" program works OK (except see note below).
Which caget are you using? Is it the caget based only CA or the caget based
on ezca?
> Sometimes, but not always, they get the following error with caget:
> C:\RSI\IDL63\misc_dlls>caget epics:calcExample
> Unexpected UDP failure WIN32 Socket Library Error 10054
Looking in the R3.13 source code one could make the guess that _WIN32 isn't
being defined by the compiler, or by the compiler's command line (this
snippet is from the R3.13 iocinf.c) when ca.dll was built? The
SOCK_ECONNRESET constant is 10054 when building CA for winsock.
# ifdef _WIN32
* Avoid ECONNRESET from disconnected socket
bug
* in win32
if (SOCKERRNO==SOCK_ECONNRESET) {
UNLOCK;
return;
# endif
ca_printf("Unexpected UDP failure %s\n", SOCKERRSTR);
Considering this further I seem to recall that you typically build using
cygwin POSIX emulation on windows instead of using the native port, and
therefore naturally _win32 wouldn't be defined. What version of cygwin is
installed at the Australian Synchrotron? I remember that earlier version of
cygwin were quite squirrelly. These versions might predate the installations
on the Australian Synchrotron. Nevertheless, based on your "Unexpected UDP
failure WIN32 Socket Library Error 10054" symptom , this still seems like a
best guess.
As for why EZCA doesn't connect and "caget" does that's harder to guess at.
Till's suggestion is definitely a possibility, but maybe that doesn't
explain why "caget" connects and ezca doesn't if you are using the "caget"
that comes with ezca, and is based on ezca. Another related possibility is
that the code is using a different cygwin dll than it was built to be
executed with.
> Another thing that they have seen is that caget to local PVs on the PC
> return instantly, while caget to PVs on the network do not return until
> after a 4 second delay.
That 4 seconds is an oddly round number. I wonder if something is squirrelly
with cygwin's "select" system call based notification for the arrival of new
incoming network messages.
Another possibility is something funny with the local network. You might try
ping to the IOC. Also, looking at icmp traffic with a sniffer can be helpful
when there are network issues.
You might also try using R3.14
Jeff
> -----Original Message-----
> From: Mark Rivers [mailto:[email protected]]
> Sent: Thursday, April 19, 2007 1:46 PM
> To: [email protected]; [email protected]
> Subject: Strange channel access problem
> Folks,
> I am trying to help diagnose a very puzzling channel access problem that
> is happening on Windows machines from IDL at the Australian Synchrotron.
> Background:
> IDL uses the following DLLs to do channel access:
> - ezcaIDL.dll A thin wrapper on top of ezca.dll and ezcaScan.dll to
> convert IDL call_external argument passing parameters to those used by
> ezca and ezcaScan.
> - ezca.dll and ezcaScan.dll. These libraries on top of ca.dll and
> com.dll that take care of looking up PVs by name, handling callbacks,
> etc.
> - ca.dll, com.dll. The standard CA libraries from EPICS base.
> I built these DLLs in 2001 with EPICS 3.13. I've used the same DLLs
> since then with all versions of IDL (up to 6.3, the current version) and
> with all versions of Windows (NT, 2000, XP). I've never had any
> problems, and it is probably running on over 100 machines at APS and
> NSLS, and other sites.
> At the Australian Synchrotron, however, they have run into a strange
> problem. They are using the exact same DLLs that we are, standard XP
> Professional SP1, and IDL 6.3. It has the following behavior:
> - ezca.dll is being called OK, because functions like caGetTimeout and
> caGetRetryCount that return values from ezca are working fine.
> - EPICS channel access is always failing to find PVs, returning failure
> after the expected timeout interval.
> This failure happens despite the following:
> - All Windows firewalls are turned off.
> - The failure happens for PVs on the network, as well as for PVs on the
> same PC running a soft IOC.
> There is some behavior on the "caget" command line program that
> indicates something is not quite right:
> epics:calcExample 9
> Even when the UDP failure message appears caget still "works"
> Sometimes this error does not occur:
> epics:calcExample 0
> In principle we should be able to turn on the rich debugging in ezca
> (Trace and Debug flags). However, that debugging output goes to stdout,
> which does not exist in the Windows version of IDL, because it is a
> "Windowing" application, not a console application, and hence has no
> place for stdout to go. We could rewrite ezca to send the output to a
> file, but that is more work than I'm in the mood for right now :-)
> Anyone have any idea what could be wrong?
> Thanks,
> Mark
- RE: Strange channel access problem Mark Rivers
- Strange channel access problem Mark Rivers
RE: Firewire (IEEE1394) Camera driver - errors in st.cmd file Mark Rivers
<2007>
2025
2026
Re: Strange channel access problem Till Straumann
<2007>
2025
2026
