1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: MV1200/dec211x40 end driver auto negotiation bug,
To: "Thompson, David H." <[email protected]>
Date: Wed, 02 May 2007 17:19:13 +0200
Dave,
we have been "playing" with these driver settings a lot.
For us, things usually seem to work with both ends (2100 and switch) being on auto-neg. Note that we only found a severe problem when one side is fixed to full-duplex (any speed), and the other side is on auto-neg. In that case, the auto-neg side falls back to half-duplex and auto-sensing. So it will get the speed right, but not the duplex configuration. The full-duplex side, when sending, will always force the half-duplex side into detecting a collision.
So far, we have not seen any 2100s getting "stuck" while both sides are on auto-neg.
Cheers,
Ralph
Thompson, David H. wrote:
Our dec driver has for some time been afflicted with just going dead for no apparent reason. It is rate but when it happens we end up rebooting the IOC. The driver seems to be trying to auto negotiate and is stuck. Messages show up on the console from CA beacons and clients when the entries in the arp table age out. The mii flags are where we get the idea that it is trying to negotiate, that and the fact that the IOC and the switch port it is connected to are on different speeds.
Does anyone know if WRS ever fixed this? If so is there a reference that I can put my tech contact at WRS on to to see if the driver that is being shipped with vxWorks 6.x includes the fix? I thought that I had heard that a fix had been done for it, possibly outside the US office of WRS.
MV1200/dec211x40 end driver auto negotiation bug, Thompson, David H.
Prev: Re: wxPython timer and KEK CaPython314 cause core dump Noboru Yamamoto
Next: Re: wxPython timer and KEK CaPython314 cause core dump Zhong Ren
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: MV1200/dec211x40 end driver auto negotiation bug, Thompson, David H.
Next: Support for Omega DP40 series meters? Mark Rivers
