1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: wxPython timer and KEK CaPython314 cause core dump
To: Noboru Yamamoto <[email protected]>
Cc: [email protected]
Date: Wed, 2 May 2007 12:05:06 -0500 (CDT)
Hi Noboru,
This is really cool now.  I did all the tests I have so far.
No crash at all.  Thank you for the new version.
Zhong
---- Original message ----
>Date: Wed, 02 May 2007 16:24:07 +0900
>From: Noboru Yamamoto <[email protected]>
>To: [email protected]
>Hi Zhong,
>Please find the latest version of my version of Python-CA
interface module.
>I'm testing your wxPython program on my MacBook( Intel Core
Duo + MacOSX
>10.4.9, Python 2.5 and wxPython2.8 installed using dmg
package) and
>it runs more than one hour now.( I set "milliseconds" to 1).
>Thank you very much again for your help and cooperation.
>Regards,
>Noboru
>Zhong Ren wrote:
>> Hi Noboru,
>> Thank you for the update.  I found that the new version did
>> not solve my problem.  I am running on an Intel duo core.
>> Anything special I need to do?  Please test the following
>> code.  All lines are necessary to reproduce the crash.  One
>> important observation is that the smaller the milliseconds,
>> the sooner the crash happens.  Try 1 or 0.1; it crashes almost
>> immediately.  Thank you for your help.
>> Zhong
>> # Segmentation fault (core dumped) occurs after
>> # running a while.
>> import wx
>> import ca
>> def onTimer(event): pass
>> print ca.__version__
>> ca.Monitor('S:SRcurrentAI') # Supply a PV here.
>> appli = wx.PySimpleApp()
>> frame = wx.Frame(None)
>> timer = wx.Timer()
>> timer.Bind(wx.EVT_TIMER, onTimer)
>> timer.Start(milliseconds = 10, oneShot = False)
>> appli.MainLoop()
>> Other info:
>>  Pyhton 2.5
>>  wxPython 2.6.3.3
>>  RedHat Linux x86_64
>>  GCC 4.1.1
>>> Date: Thu, 26 Apr 2007 14:29:00 +0900
dump
>>> Hi,
>>> I have updated my version of CA-Python interface module.
>>> Please find a new tar.gz file as an attachment to this e-mail.
>>> It may have multi core CPU(such as Intel Core Duo on my
MacBook).
>>> As far as I tested, it runs stable on a single core
>> processors, i686 and
>>> PPC.
>>> Best regards,
>>> Noboru
>>> Zhong Ren wrote:
>>>> Dear Noboru,
>>>> Thank you.  I must say the KEK CaPython314 is very easy
to use.
>>>> I am not surprised that your little test below won't crash,
>>>> since it does not contain a wx.Timer.  In order to repeat my
>>>> crash, a wx.Timer must be constructed, it must be bound to a
>>>> onTimer function, and it must be started.  Using
>>>> threading.Timer instead of wx.Timer will not cause the crash.
>>>>  I cannot tell who is guilty, wx.Timer or CaPython314.  I
also
>>>> have the feeling that Python 2.5 may be the problem.
>>>> Zhong
>>>>> Date: Wed, 06 Dec 2006 10:47:29 +0900
>> dump
>>>>> Hi,
>>>>> I'm not familiar with WxPytho (yet).
>>>>> But, the following code works on MacBook running MacOSX
>>>> 10.4.8 with
>>>>> Python2.5,
>>>> wxPython2.7-osx-unicode-2.7.2.0-universal10.4-py2.5.dmg
>>>>> and KEK version of CaPython314 ( I should have used the
>>>> different name
>>>>> to avoid confusion with FNAL version. Sorry).
>>>>> import wx,ca
>>>>> class MyApp(wx.PySimpleApp):
>>>>>    def OnInit(self):
>>>>>        frame = wx.Frame(None, -1, "Hello from wxPython")
>>>>>        frame.Show(True)
>>>>>        self.frame=frame
>>>>>        self.ch=ca.channel("fred")
>>>>>        self.ch.wait_conn()
>>>>>        self.ch.monitor(self.ca_callback)
>>>>>        self.ch.flush()
>>>>>        self.SetTopWindow(frame)
>>>>>        return True
>>>>>    def ca_callback(self,valstat):
>>>>>        self.ch.update_val(valstat)
>>>>>        self.frame.Title="%s:%f"%(self.ch.name,self.ch.val)
>>>>> if __name__ == "__main__":
>>>>>    app = MyApp(0)
>>>>>    app.MainLoop()
>>>>> I hope this can give some idea.
>>>>> Regards,
>>>>> Noboru Yamamoto
>>>>> EPICS group/J-PARC control group
>>>>> KEK, JAPAN
>>>>> Zhong Ren wrote:
>>>>>> I managed to isolate a core dump in a minimized Python code
>>>>>> (see below).  I found two components are essential to
cause a
>>>>>> core dump: wx.Timer and ca.Monitor (or ca.Get).  Can
someone
>>>>>> tell what the problem is?
>>>>>> import wx
>>>>>> import ca
>>>>>> timer = wx.Timer()
>>>>>> appli.MainLoop()
>>>>>> Other info:
>>>>>> Pyhton 2.5
>>>>>> wxPython 2.6.3.3
>>>>>> RedHat Linux x86_64
>>>>>> GCC 4.1.1
>>>>>> To test, let the routine run for a while.  A core dump will
>>>>>> occur in a few minutes.
>>>>> ________________
>>> ________________
>>> CaPython-1.7.tar.gz (40k bytes)
>>> ________________
>>> noboru.yamamoto.vcf (1k bytes)
>________________
>CaPython-1.9.tar.gz (41k bytes)
>________________
Re: wxPython timer and KEK CaPython314 cause core dump Noboru Yamamoto
Prev: Re: MV1200/dec211x40 end driver auto negotiation bug, Ralph Lange
Next: Support for Omega DP40 series meters? Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: wxPython timer and KEK CaPython314 cause core dump Noboru Yamamoto
Next: Re: wxPython timer and KEK CaPython314 cause core dump Noboru Yamamoto
