1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: GigE Vision-compliant cameras
From: "Pearson, MR \(Matthew\)" <[email protected]>
To: "Malitsky, Nikolay D" <[email protected]>, <[email protected]>
Date: Mon, 11 Jun 2007 09:06:00 +0100
We've tried out a GigE Pulnix TMC-1405GE here at Diamond. But we don't
yet use these cameras on beamlines or in the machine. We found that this
particular camera wasn't sensitive enough for some applications (like
using a microscope lens) and did put a lot of load on to the gigabit
ethernet network (3MB images at 30Hz). To use something like this in
production will probably require us to partition the ethernet and make a
separate 'GigE camera subnet', and provide a server gateway to handle
the video, do the compression, etc. Although if you have a camera that
can operate at low frame rate this isn't such an issue.
Other issues you have to think about mainly do to with performance of
the network stack. There are high performance GigE compliant network
drivers that use DMA and greatly reduce the CPU load on the machine
handling the video (as much as 30-40% less load, to down to a few %). I
tried out a couple of these drivers that came with my camera, and they
do make a huge difference. However, this may restrict the NIC to be used
with GigE only, and might cease to work with standard networking.
The camera we have came with a windows API and application software,
which is what we used to do the tests. I'm not sure if there are generic
windows / Linux GigE drivers yet....
Also, GigE cameras are quite expensive at the moment, since it's a new
technology. And the software standards are only just being standardized
(or only recently anyway). So it's also good to think about shielding of
the camera body, and to think about heat transfer (I thought about
gluing a CPU heat sink onto the side of my camera!).
Cheers,
Matthew
-----Original Message-----
[mailto:[email protected]] On Behalf Of Malitsky, Nikolay D
Sent: 11 June 2007 02:59
To: [email protected]
Subject: GigE Vision-compliant cameras
 Hello,
Does anyone have EPICS-based solution or experience with GigE
Vision-compliant cameras. We are considering GC-1020 from Prosilica for
the ERL Beam Profile Monitor system
(http://www.prosilica.com/products/gc1020.html
<https://exchange2000.bnl.gov/exchweb/bin/redir.asp?URL=https://exchange
2000.bnl.gov/exchweb/bin/redir.asp?URL=http://www.prosilica.com/products
/gc1020.html> ).
Thank you,
Nikolay Malitsky
<DIV><FONT size="1" color="gray">This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient of the addressee please notify us of receipt by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail.
</FONT></DIV>
GigE Vision-compliant cameras Malitsky, Nikolay D
Prev: RE: the first installing jca2.1.2 problem Pearson, MR (Matthew)
Next: StreamDevice version 2.2 released Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: GigE Vision-compliant cameras Malitsky, Nikolay D
