1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: StreamDevice version 2.2 released
To: TechTalk EPICS <[email protected]>
Date: Mon, 11 Jun 2007 10:54:58 +0200
Hi all,
a new version of StreamDevice is now released. Upgrade is recommended especially if you are running a CVS-snapshot version. (If you have already found version 2.2 and downloaded it before 4th of June, download again. That version was buggy.)
The new version includes several bugfixes and new features since 2.1 (some of them were already included in patches or the snapshot versions):
Bugfixes:
Deadlock in exec command
Problems with Terminator=""
Waveform read bug
Registration problems in vxWorks and cygwin
@mismatch handler missing
Crashes in streamReload and other places
asynOverflow problem with GPIB
"I/O Intr" problems
Features:
%(FIELD) and $(record.FIELD) redirection syntax
aai and aao support
connect / disconenct commands
Use terminators defined by asynDriver as default
Support for base R3.13.7+ on vxWorks
Patches for base R3.14.9 and gcc 4.1.1
Support of Windows and RTEMS
Download: http://epics.web.psi.ch/software/streamdevice/
Dirk
-- Dr. Dirk Zimoch Computing and Controls Paul Scherrer Institut phone +41 56 310 5182 fax +41 56 310 4413
Prev: RE: GigE Vision-compliant cameras Pearson, MR (Matthew)
Next: IK320 problem Shepherd, EL (Emma)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
