1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: IOC options
To: [email protected]
Date: Wed, 13 Jun 2007 11:55:41 +0200
Hi
We have just started investigating using EPICS :)
So far so good.
The one problem we have is that we have tons of existing hardware (lotsa
it is custom made) that I will need to interface. Luckily most if this
hardware works on a fairly simple bus interface (once again custom made)
I was thinking that the following might be options:
1. To have a small linux pc (pc104?) and put in some or other card
(maybe NI) to interface the hardware and run the IOC software on here
Having a strict real-time system isn't really important.
The problem I have with this setup is that I will probably have to
develop some in-between interface to go between the pc and the hardware.
Or I need to figure out how to get NI cards working under linux.. but
even with that we need in-between devices.
2. The other option I like is the idea of using a ARM processor.
Now If I'm not mistaken I can run EPICS on Linux on ARM - correct?
What do I need on my ARM system for this to work? In terms of flash/ram.
How difficult will the be to get working?
Or maybe somebody has already done something similar?
I appreciate any help!
-Heinrich du Toit
iThemba LABS
Ps. Is there anybody in South-Africa making use of EPICS?
Re: IOC options Heinrich du Toit
Prev: VxWorks Buffer Problems Matt Rippa
Next: Re: IOC options Heinrich du Toit
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: VxWorks Buffer Problems Jeff Hill
