1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: protocol/database macro expansion problem
To: TechTalk EPICS <[email protected]>
Date: Fri, 15 Jun 2007 09:36:19 +0200
Hi Matthew,
The problem is the space. Write: setD($(P):P,$(P):I)
The reason is the way the string is parsed. I probably should ignore spaces
inside the ().
Dirk
Pearson, MR (Matthew) wrote:
I'm trying to get the following protocol function and record to work:
setD {
   out "PID 1,%(\$1.VAL)f,%(\$2.VAL)f,%f";
record(ao, "$(P):D_S") {
  field(DTYP, "stream")
  field(OUT, "@ls340.proto setD($(P):P, $(P):I) $(PORT) $(ADDR)")
but at IOC startup I get:
2007/06/14 18:20:37.973 Businterface 'BL16I-EA-LS340-01:I)' not found
for 'BL16I-EA-LS340-01:D_S'
2007/06/14 18:20:37.973 BL16I-EA-LS340-01:D_S: Can't attach to bus
BL16I-EA-LS340-01:I) -1
2007/06/14 18:20:37.976 BL16I-EA-LS340-01:D_S: Record initialization
failed
Bad init_rec return value  PV: BL16I-EA-LS340-01:D_S ao: init_record
But if I only use the main PV name, and hard code the last part of the PV into the protocol file, so that I only have one macro, then this works. eg.
setD {
   out "PID 1,%(\$1:P.VAL)f,%(\$1:I.VAL)f,%f";
  field(OUT, "@lakeshore340.proto setD($(P)) $(PORT) $(ADDR)")
but this isn't ideal because then two files are dependant on the last
part of the PV name.
Any ideas? Is it because I'm trying to expand two macros?
Cheers,
Matthew
-- Dr. Dirk Zimoch Computing and Controls Paul Scherrer Institut phone +41 56 310 5182 fax +41 56 310 4413
RE: protocol/database macro expansion problem Pearson, MR (Matthew)
Prev: RE: protocol/database macro expansion problem Pearson, MR (Matthew)
Next: RE: protocol/database macro expansion problem Pearson, MR (Matthew)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
