1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: VXI11 ASYN problem on VxWorks
To: Eric Norum <[email protected]>
Cc: tech-talk talk <[email protected]>
Date: Mon, 18 Jun 2007 08:25:41 +0100
Nothing that I'm aware of could be blocking UDP. The Linux machine where I was running the soft IOC is on the same subnet as the VxWorks machine and the E5810A. Someone suggested here that I should try running the soft IOC on a linux laptop plugged into the same ethernet port as the VxWorks machine, just to double check this.
By the way, if this is relevant, the firmware version on the E5810A is A.01.02.
Also, I don't think I have changed any settings, apart maybe getting it to boot via DHCP.
Cheers,
Matthew
On Fri, 2007-06-15 at 11:17 -0500, Eric Norum wrote:
We use quite a few E5810s here.  Most with systems other than
vxWorks, though.
The error you're seeing is coming from clnttcp_create when it is
trying to map the VXI-11 RPC program and version number to a TCP port
number on the E5810.  Do you have any network gateways between the
IOC and the E5810 that could be blocking the UDP request to the
portmapper in the E55810?   Is your 55810 set to its factory defaults?
On Jun 15, 2007, at 10:29 AM, Matthew Pearson wrote:
> Hi,
> I'm trying to use a GPIB device via the VXI11 Agilent E5810A, by
> using the ASYN support for the E5810A. So in my IOC start up file I
> have:
> iocshCmd("vxi11Configure L0 172.23.116.185 0 0.0 gpib0 0 0")
> but at start up I get:
> 2007/06/15 15:17:53.852 L0 vxiConnectPort error 172.23.116.185:
> RPC: Program not registered
> 2007/06/15 15:17:53.852 asynManager::asynConnectCallback, port L0
> error calling asynCommon->connect
> 2007/06/15 15:17:53.852  L0 -1 autoConnect could not connect
> 2007/06/15 15:17:53.885 L0 vxiConnectPort error 172.23.116.185:
> 2007/06/15 15:17:53.968 asynManager::asynConnectCallback, port L0
> 2007/06/15 15:17:54.868 L0 port not connected
> 2007/06/15 15:17:58.618 L0 vxi11 clientCall errno 3997698 clnt_stat 0
> 2007/06/15 15:17:58.618 L0 vxiConnectPort vxiBusStatus error
> initialization aborted
> 0x1ea12bc0 (L0): memPartFree: invalid block 0x1e247e80 in partition
> 0x265d1c.
> Have people seen something like this before? I'm not sure if the
> E5810A is widely used or not.
> The device itself is fine. The above works OK if I am using a linux
> IOC. Also, the VxWorks IOC can see the E5810A because it send a
> reboot command successfully.
> Cheers,
> Matthew
Diamond Light Source Limited (company no. 4375679). Registered in England and Wales with its registered office at Diamond House, Harwell Science and Innovation Campus, Didcot, Oxfordshire, OX11 0D! E, United Kingdom
VXI11 ASYN problem on VxWorks Matthew Pearson
Re: VXI11 ASYN problem on VxWorks Eric Norum
Prev: Re: EPICS channels via the Internet Pete R. Jemian
Next: RE: EPICS channels via the Internet Purcell, J. David
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: VXI11 ASYN problem on VxWorks Eric Norum
Next: support for Pfeiffer RGA? Schuh, Stephen
