1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: EPICS channels via the Internet
To: "Doug Sheffer" <[email protected]>, <[email protected]>
Date: Mon, 18 Jun 2007 14:12:09 -0500
This is just another way to view data instead of allowing access to
write.  I put together a perl script which can be used to do a "live"
display of data.  It basically parses output from caget and creates a
popup.  We are even doing the caget through a gateway.  I have included
the code below.  Remember that this is probably only good for a couple
of channels and probably not the best solution for long durations since
this does active polling every 10 seconds or so.
Also note that on line 5 of the code I took out our IP address.
We also have code that puts together paged output but this is a static
look that runs every 5 minutes to 1 hour.  This runs as a cron task.
John
#!/usr/bin/perl
use CGI;
use Env;
#name changed to protect the innocent.
$ENV{'EPICS_CA_ADDR_LIST'} ='XXX.XXX.XXX.XXX';
$ENV{'PATH'}='/net/iocapps/R3.13.7/extensions/3-13-7/bin/Linux/:/net/ioc
apps/R3.13.7/base/3-13-7/bin/Linux/';
$ENV{'LD_LIBRARY_PATH'}='/net/iocapps/R3.13.7/base/3-13-7/lib/Linux:/net
/iocapps/R3.13.7/extensions/3-13-7/lib/Linux';
$caget='/net/iocapps/R3.13.7/extensions/3-13-7/bin/Linux/caget';
#$beam_curr = `$caget 'IPNS:Beam_Current'` ;
#print $beam_curr;
use Env qw/PATH/;
$page = new CGI;
print $page->header;
print ( '<head>');
print ('<body bgcolor="#d0d0d0">');
print ('<style type=text/css>');
print ('h1 {font-size:600%}');
print ('</style>');
$bcurr = `$caget -t IPNS:Beam_Current`;
printf ('<title>%6.2f&#181A</title>',$bcurr);
print('<meta HTTP-EQUIV="REFRESH" CONTENT="3">');
print('</head>');
#print $page->start_html('IPNS Beam Current!');
#print ('<b>IPNS Beam Current</b><br>');
print ('<font size=+6>');
printf('%6.2f &#181A', $bcurr);
print('</font>');
$ltime = localtime(time);
printf ('<font size=-1> <br>  %s</font>', $ltime);
print('</html>');
John Hammonds
Beamline and Data Acquisition Group
APS Engineering Support Division
Argonne National Laboratory
[email protected]
(630)252-5317
-----Original Message-----
[mailto:[email protected]] On Behalf Of Doug Sheffer
Sent: Friday, June 08, 2007 1:57 PM
To: [email protected]
Subject: EPICS channels via the Internet
Hello!
I was wondering if anyone has experimented and had good luck with
accessing real-time EPICS channel data over the Internet.  Is this, by
any chance, something that is possible with the EPICS gateway?
Since allowing access over the Internet in any way would inevitably be
a large security risk, we would like to be able to use SSH tunneling
to secure the connection and to monitor who is doing what with the
system.  Unfortunately, SSH seems unsuitable because it only supports
tunneling on TCP ports, while EPICS uses both TCP and UDP.
Has anyone done anything similar, or got any ideas/suggestions on how
to go about doing it securely?
Your help is much appreciated.
Doug Sheffer
EPICS channels via the Internet Doug Sheffer
Prev: Re: EPICS channels via the Internet Doug Sheffer
Next: RE: EPICS channels via the Internet Purcell, J. David
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: EPICS channels via the Internet Jeff Hill
Next: RE: EPICS channels via the Internet Elder Matias
