1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EPICS channels via the Internet
To: [email protected]
Date: Fri, 8 Jun 2007 14:57:13 -0400
Hello!
I was wondering if anyone has experimented and had good luck with
accessing real-time EPICS channel data over the Internet.  Is this, by
any chance, something that is possible with the EPICS gateway?
Since allowing access over the Internet in any way would inevitably be
a large security risk, we would like to be able to use SSH tunneling
to secure the connection and to monitor who is doing what with the
system.  Unfortunately, SSH seems unsuitable because it only supports
tunneling on TCP ports, while EPICS uses both TCP and UDP.
Has anyone done anything similar, or got any ideas/suggestions on how
to go about doing it securely?
Your help is much appreciated.
Doug Sheffer
Re: EPICS channels via the Internet J. Lewis Muir
RE: EPICS channels via the Internet Hammonds, John P.
Prev: Re: Automatically generate iocsh registrar code? Carl Lionberger
Next: Re: EPICS channels via the Internet J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: the problem in the first installing jca2. 1.2 reouhzoahz
