Doug Sheffer wrote:
Hello!
I was wondering if anyone has experimented and had good luck with
accessing real-time EPICS channel data over the Internet. Is this, by
any chance, something that is possible with the EPICS gateway?
Since allowing access over the Internet in any way would inevitably be
a large security risk, we would like to be able to use SSH tunneling
to secure the connection and to monitor who is doing what with the
system. Unfortunately, SSH seems unsuitable because it only supports
tunneling on TCP ports, while EPICS uses both TCP and UDP.
Has anyone done anything similar, or got any ideas/suggestions on how
to go about doing it securely?
Your help is much appreciated.
Doug Sheffer
You could use a VPN. It depends on what you want to do. Or maybe you
have constraints that make this not an option?
-lewis
J. Lewis Muir
Software Engineer
CARS/IMCA-CAT
- Re: EPICS channels via the Internet Emmanuel Mayssat
- EPICS channels via the Internet Doug Sheffer
<2007>
2025
2026
<2007>
2025
2026
