1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS channels via the Internet
To: "J. Lewis Muir" <[email protected]>
Cc: [email protected]
Date: Fri, 08 Jun 2007 14:02:27 -0700
I do something very similar but with a nx server/client architecture.
Have a look at freenx and nxclient (nomachine.com)
The idea is that you do not forward the PV directly, but a display with
the values of the PV. The nx protocol is TCP based, use ssl encryption
(over ssh), and use compression.
With a gateway over the internet, you will probably lose most of your
UDP datagrams anyway, plus there is the network latency, etc.
I heard that a secure epics gateway is being developed though.
How far are you from the IOCs ?
Emmanuel Mayssat
On Fri, 2007-06-08 at 15:09 -0400, J. Lewis Muir wrote:
> Doug Sheffer wrote:
> > Hello!
> > I was wondering if anyone has experimented and had good luck with
> > accessing real-time EPICS channel data over the Internet.  Is this, by
> > any chance, something that is possible with the EPICS gateway?
> > Since allowing access over the Internet in any way would inevitably be
> > a large security risk, we would like to be able to use SSH tunneling
> > to secure the connection and to monitor who is doing what with the
> > system.  Unfortunately, SSH seems unsuitable because it only supports
> > tunneling on TCP ports, while EPICS uses both TCP and UDP.
> > Has anyone done anything similar, or got any ideas/suggestions on how
> > to go about doing it securely?
> > Your help is much appreciated.
> > Doug Sheffer
> You could use a VPN. It depends on what you want to do. Or maybe you
> have constraints that make this not an option?
> -lewis
Re: EPICS channels via the Internet Doug Sheffer
Re: EPICS channels via the Internet J. Lewis Muir
Prev: Re: EPICS channels via the Internet J. Lewis Muir
Next: Re: EPICS channels via the Internet Doug Sheffer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
