a piece of my code:
result = pasynManager->registerPort("port0",ASYN_MULTIDEVICE|
ASYN_CANBLOCK,1,0,10);
if (result != 0)
printf("result = %d\n",result);
result = pasynManager->registerInterface("port0", &myadevInterface0);
if (result != 0)
result = pasynManager->registerInterface("port0", &myadevInterface1);
if (result != 0)
the first interface is asynCommon
the second one is asynInt32
all functions in both interfaces are defined, although they don't really
do much. Accept the connect/disconnect calls the connect/disconnect
exceptions.
should I load some other interface to get asynRecord to work?
But since it seems to be some locking mechanism failing, I don't
understand how this can be my code in the first place? :) but it
probably is.
On Tue, 2007-06-19 at 07:34 -0500, Mark Rivers wrote:
> The PORT field is set to Port0. Is that the name of your asyn port? It should not matter if it is an invalid port name, but you could try setting PORT to the name of your port, and see if it makes a difference.
> Mark
> ________________________________
> From: Heinrich du Toit [mailto:[email protected]]
> Sent: Tue 6/19/2007 7:06 AM
> To: Mark Rivers
> Subject: RE: asynRecord SEGFAULT?
> ok?
> epics>
> dbl
> heinrich:inputa
> heinrich:inputf
> asynA
> epics> dbpr "asynA",5
> ACKS: NO_ALARM ACKT: YES ACMD: None ADDR:
> 6
> AINP: AOUT: AQR: 0
> ASG:
> ASP: 0x00000000 AUCT: noAutoConnect BAUD: Unknown BINP:
> 0
> BKPT: 0x00 BOUT: 0 CNCT: Disconnect DBIT:
> Unknown
> DESC: DISA: 0 DISP: 0 DISS:
> NO_ALARM
> DISV: 1 DPVT: 0x00000000 DRVINFO: DSET:
> 0x00000000
> DTYP: asynRecordDevice ENBL: Disable EOMR:
> None
> ERRS: 0x00000000 EVNT: 0 F64INP: 0 F64IV:
> 0
> F64OUT: 0 FCTL: Unknown FLNK:CONSTANT 0 GPIBIV:
> 0
> I32INP: 0 I32IV: 0 I32OUT: 0
> IEOS:
> IFACE: asynOctet IFMT: ASCII IMAX: 0 IPTR:
> 0x00000000
> LCNT: 0 LSET: 0x00000000 MCTL: Unknown
> MLIS: 0x000000000000000000000000 MLOK: 0x00000000 NAME:
> asynA
> NAWT: 0 NORD: 0 NOWT: 80 NRRD:
> 0
> NSEV: NO_ALARM NSTA: NO_ALARM OCTETIV: 0
> OEOS:
> OFMT: ASCII OMAX: 0 OPTIONIV: 0 OPTR:
> 0x00000000
> PACT: 0 PCNCT: Disconnect PHAS: 0 PINI:
> NO
> PORT: Port0 PPN: 0x00000000 PPNR: 0x00000000 PRIO:
> LOW
> PROC: 0 PRTY: Unknown PUTF: 0 RDES:
> 0x00000000
> REASON: 0 RPRO: 0 RSET: 0x00000000 SBIT:
> Unknown
> SCAN: Passive SDIS:CONSTANT SEVR: INVALID
> SOCK:
> SPR: 0 SPVT: 0x00000000 STAT: UDF TB0:
> Off
> TB1: Off TB2: Off TB3: Off TB4:
> Off
> TFIL: TIB0: Off TIB1: Off TIB2:
> Off
> TIME: <undefined> TINP: TIOM: 0 TMOD:
> Write/Read
> TMOT: 1 TMSK: 0 TPRO: 0 TSE:
> 0
> TSEL:CONSTANT TSIZ: 0 UCMD: None UDF:
> 1
> UI32INP: 0 UI32IV: 0 UI32MASK:
> 4294967295
> UI32OUT: 0 VAL:
> On Tue, 2007-06-19 at 06:43 -0500, Mark Rivers wrote:
> > Before running medm on the asyn record, at the ioc prompt you could do:
> > dbpr "myAsynRecord",5
> > That might help find the problem.
> > Mark
> > From: [email protected] on behalf of Heinrich du Toit
> > Sent: Tue 6/19/2007 5:44 AM
> > To: TechTalk EPICS
> > Subject: asynRecord SEGFAULT?
> > Hi
> > I've started experimenting with asyn.
> > Now I've created the routines for a driver with Common and devInt32
> > interfaces.
> > When I connected my own record (ai) 2 this to read it works fine.
> > Then I tried connecting a asynRecord to this.
> > It starts up fine.
> > But when I run medm to see this record the IOC segfaults.
> > location: base/src/db/dbLock.c line 242 : plockSet =
> > plockRecord->plockSet
> > because plockSet = null
> > and this is because precord->lst = null
> > And that must be the lockRecord or something.
> > I don't understand, the stack trace doesn't even run through asyn or my
> > own code.
> > I have no idea where to look for the fault :(
> > -Heinrich
- RE: asynRecord SEGFAULT? Mark Rivers
- asynRecord SEGFAULT? Heinrich du Toit
<2007>
2025
2026
<2007>
2025
2026
