1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: PV save and restore tool sought
Cc: [email protected]
Date: Thu, 28 Jun 2007 12:43:19 -0400
One simple-minded approach I have recently taken works with Kay's channel archiver.
I made a simple mod to the archiveExport utility so that the command
ArchiveExport -snapshot -format decimal -precision 6 -start "06/27/2007 00:00:00" -end "06/27/2007 00:00:00" /a/20070614_015041/Arc t:esx_t-2:volt_ctl
produces the following kind of output:
#06/26/2007 07:16:50.242633762
caput t:esx_t-2:volt_ctl "2.930956"
The mod makes the -snapshot option available, so don't try this with the current
distribution.
So, then I build a file from a list of pvs like the following:
echo "Timestamp: $1"
echo "Archive: $2"
echo "Output file is: out"
ArchiveExport -snapshot -format decimal -precision 6 -start "$1" -end "$1" $2 t:h2_c4_L2 >> out
ArchiveExport -snapshot -format decimal -precision 6 -start "$1" -end "$1" $2 t:h2_c11_L2 >> out
ArchiveExport -snapshot -format decimal -precision 6 -start "$1" -end "$1" $2 t:h2_c16_L2 >> out
The saved values are restored by executing the output file, as shown below.
./out
OK, not very nice, but an integrated utility to do all this in a straightforward manner would be
great to have.
- John Sinclair
Andrew Johnson wrote:
Matthias Clausen wrote:
Is there a volunteer to compute a list of 'problems to be solved' versus 'tools to be used'?
At least I would add our tools to that list.
Could this be a wiki page at APS? - Andrew??
Sure, that would seem appropriate - if anyone doesn't already have a Wiki account they should email me to have one created. I created an initial page with a pointer to the SynApps Autosave package for starters, linked from the HowTo Documents wiki page, found at
http://www.aps.anl.gov/epics/wiki/index.php/What_PV_Save_and_Restore_Tools_are_available
Note that there are a number of save/restore tools listed on the Soft Support page at http://www.aps.anl.gov/epics/modules/soft.php - this would be a good place to start for more tools.
- Andrew
Attachment: smime.p7s
Description: S/MIME Cryptographic Signature
PV save and restore tool sought Rock, Judith E.
Re: PV save and restore tool sought Emmanuel Mayssat
Re: PV save and restore tool sought Matthias Clausen
Re: PV save and restore tool sought Andrew Johnson
Prev: Re: medm, edm, other on fc6 Guy Jennings
Next: RE: asynRecord and Labview problem Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: PV save and restore tool sought Andrew Johnson
Next: Re: PV save and restore tool sought Thomas Birke
