1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: GPIB Ethernet gateway recommendation
To: Jiro Fujita <[email protected]>
Cc: [email protected]
Date: Fri, 29 Jun 2007 18:27:35 -0700
Jiro Fujita wrote:
Can anybody recommend me a good GPIB Ethernet gateway for using with
EPICS?  I will be using it with a Linux machine working as soft IOC.
I know Aglent E5810A has been discussed on Tech-Talk, but I am curious
if anybody have a recommendation on a device like that.
Also, if anybody have a information/suggestion on using one of these
device as oppose to using a PCI GPIB interface card, that would be a
welcome.  In particular, I am most interested in the reliability of
GPIB Ethernet gateway as opposed to using a PCI card.
We have used the National Instruments GPIB-Ethernet (10 Mbit version) with a driver based on the NI driver package and an older version of StreamDevice, all on vxWorks. This never really worked well, probably because of the glue code I wrote to interface the NI code with the StreamDevice layer. We recently replaced one such system with the combination of NI PCI GPIB/Linux-GPIB/StreamDevice/Asyn and I am much happier with it. We are running EPICS 13.14.8.2 on Scientific Linux 4.4. I hope to never use the GPIB Ethernet boxes with EPICS again. If you require a small form factor, you might look at the above configuration hosted on PC104 hardware.
Rod Nussbaumer
ISAC Controls, TRIUMF
Vancouver, Canada.
GPIB Ethernet gateway recommendation Jiro Fujita
Prev: GPIB Ethernet gateway recommendation Jiro Fujita
Next: Re: asyn record support - output Marty Kraimer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: GPIB Ethernet gateway recommendation Pearson, MR (Matthew)
