1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: tds3000
To: Heinrich du Toit <[email protected]>
Cc: TechTalk EPICS <[email protected]>
Date: Tue, 03 Jul 2007 12:08:16 -0500
Heinrich,
The default TDS3000/5000 support is configured for 10k data points, as floats, for each waveform record. So each waveform only requires a little more than 40k bytes to be transfered. The 100k setting for EPICS_CA_MAX_ARRAY_BYTES from this support package is an over kill for this device. This setting only reflected the default setting at the APS control system. Since the release of this support, APS control system has increased this default setting to 140k to accommodate other control applications. So the very minimum setting for this support should be something like 42k for this environment variable. This should be more than enough for the preamble & data of each waveform. The setting of 100k can be misleading, my apologies.
Regarding the blinking/flashing issue. I believe I have only seen this happen when the scopeAutoArmPrint sequence program was running. This program is only supplied as reference and was only used for single sequence acquire mode. I believe the program scans for an external condition before rearming the scope, but while it scans, it maybe resetting some scope settings, which may be causing the blinking/flashing. I just check a TDS5054 scope that does not have this sequence program installed and no blinking/flashing was observed. The scan rate was also set to .5 second.
Is this sequence program running on your IOC?
Nick DiMonte
Heinrich du Toit wrote:
Hi
I've compiled the tds3000 library. And connected it to a tds5000 scope.
Works great.
Just something that bothers me.
It seem like the thing need to work with 100000 values in the array.
Now firstly this seems to make anything more than .5 refresh rate
impossible. Why is this? It's not like you can really plot 100K points?
1K would be more than enough.
Plus if I put the MEDM screen in single display mode the whole thing
would blink/flash a few times when it refreshes.
I have accelerated nvidia - ubuntu setup so it's not the pc that's 2
slow. It seem the thing redraws the screen about 20+ times everytime.
Once again not needed I think. ?
Most of all this is irritating and I can't go and put up a flashing
scope display in the control room :)
I tried changing the epicsEnvSet(EPICS_CA_MAX_ARRAY_BYTES, 100000)
line in st.cmd
But this seems to break the system completely :( Guess it's hard coded
somewhere.
If this can't be modified that's ok.
I can work with multi-display and keep update rate 1 sec or slower.
Was just wondering.
Thanks
-Heinrich
tds3000 Heinrich du Toit
Prev: RE: tds3000 Jeff Hill
Next: building EPICS for Canberra MCA on Windows XP Justin Coleman
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
