1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Scan question
To: "Heinrich du Toit" <[email protected]>, "TechTalk EPICS" <[email protected]>
Date: Thu, 12 Jul 2007 12:52:22 -0500
I think it would be a bad idea for a record to change the SCAN field.
That is something that you should let the database designer do.  They
may want to use your record in ways you never thought of.
However, if you really want your record to process again when something
happens then the record code can request reprocessing without changing
the SCAN field.  There are several ways to do this (scanOnce,
processRequestProcessCallback) depending on the application.  Look at
the Application Developer's Guide.
> -----Original Message-----
> From: [email protected]
> [mailto:[email protected]] On Behalf Of Heinrich du Toit
> Sent: Thursday, July 12, 2007 9:05 AM
> To: TechTalk EPICS
> Subject: Scan question
> Can I change the SCAN field at runtime?
> E.g. inside my own custom record.
> Some devices normally needs only be scanned say once a sec or every 5
> secs. But then when you change the value you want the scanned
> faster at
> say 0.2 secs.
Re: Scan question John Sinclair
Scan question Heinrich du Toit
Prev: Re: Scan question Emmanuel Mayssat
Next: Re: Scan question Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Scan question John Faucett
Next: Re: Scan question John Sinclair
