1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Scan question
To: TechTalk EPICS <[email protected]>
Date: Fri, 13 Jul 2007 15:35:22 -0400
Actually, when I ported the tandem controls to EPICS, I modified a couple of the
standard records (ai, ao, mbbiDirect, mbboDirect) to be able to manipulate the scan value inside
the record's own code. The remote I/O throughput was too low to have all the records scan at
a rate fast enough to make I/O sufficiently responsive during beam tuning. In the old system
(no network), several process variables could be assigned to knobs and meters which would
cause them to be processed at a higher scan rate. So I used the same scheme. I added a
fastscan and slowscan field to the database along with several fields to manage the assignment
operation. When the PV was "assigned" (to a knob or meter, in this case), an assignment reference
count was incremented. When deassigned, the count was decremented. When the count became
non-zero or zero, the scan field got the value of fastscan or slowscan respectively. In this case
I obviously needed the record to manage the scan value rather than some external agent.
Ain't EPICS wonderful.
John Sinclair
Mark Rivers wrote:
I think it would be a bad idea for a record to change the SCAN field.
That is something that you should let the database designer do.  They
may want to use your record in ways you never thought of.
However, if you really want your record to process again when something
happens then the record code can request reprocessing without changing
the SCAN field.  There are several ways to do this (scanOnce,
processRequestProcessCallback) depending on the application.  Look at
the Application Developer's Guide.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Heinrich du Toit
Sent: Thursday, July 12, 2007 9:05 AM
To: TechTalk EPICS
Subject: Scan question
Can I change the SCAN field at runtime?
E.g. inside my own custom record.
Some devices normally needs only be scanned say once a sec or every 5
secs. But then when you change the value you want the scanned faster at
say 0.2 secs.
Attachment: smime.p7s
Description: S/MIME Cryptographic Signature
Re: Scan question Ralph Lange
RE: Scan question Mark Rivers
Prev: Re: ASLO / AOFF scaling for ai and ao record Tim Mooney
Next: Re: ASLO / AOFF scaling for ai and ao record Stefan Heim
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Scan question Mark Rivers
Next: Re: Scan question Ralph Lange
