1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Scan question
To: "John Sinclair" <[email protected]>, "TechTalk EPICS" <[email protected]>
Date: Sat, 14 Jul 2007 13:29:55 -0500
> When deassigned, the count was decremented. When
> the count became non-zero or zero, the scan field got the value of
fastscan or slowscan
> respectively.
> In this case I obviously needed the record to manage the scan value
rather than some
> external agent.
Maybe I'm missing something, but I don't see why an EPICS record like
calcout could not be making those changes to the SCAN field based on the
reference count (as long as the reference count was available to EPICS).
That way standard records could be used.
> -----Original Message-----
> From: [email protected]
> [mailto:[email protected]] On Behalf Of John Sinclair
> Sent: Friday, July 13, 2007 2:35 PM
> To: TechTalk EPICS
> Subject: Re: Scan question
> Actually, when I ported the tandem controls to EPICS, I modified a
> couple of the
> standard records (ai, ao, mbbiDirect, mbboDirect) to be able to
> manipulate the scan value inside
> the record's own code. The remote I/O throughput was too low
> to have all
> the records scan at
> a rate fast enough to make I/O sufficiently responsive during beam
> tuning. In the old system
> (no network), several process variables could be assigned to
> knobs and
> meters which would
> cause them to be processed at a higher scan rate. So I used the same
> scheme. I added a
> fastscan and slowscan field to the database along with
> several fields to
> manage the assignment
> operation. When the PV was "assigned" (to a knob or meter, in this
> case), an assignment reference
> count was incremented. When deassigned, the count was
> decremented. When
> the count became
> non-zero or zero, the scan field got the value of fastscan or
> slowscan
> respectively. In this case
> I obviously needed the record to manage the scan value rather
> than some
> external agent.
> Ain't EPICS wonderful.
> John Sinclair
> Mark Rivers wrote:
> > I think it would be a bad idea for a record to change the
> SCAN field.
> > That is something that you should let the database designer
> do.  They
> > may want to use your record in ways you never thought of.
> > However, if you really want your record to process again
> when something
> > happens then the record code can request reprocessing
> without changing
> > the SCAN field.  There are several ways to do this (scanOnce,
> > processRequestProcessCallback) depending on the
> application.  Look at
> > the Application Developer's Guide.
> > Mark
> Heinrich du Toit
> >> Sent: Thursday, July 12, 2007 9:05 AM
> >> To: TechTalk EPICS
> >> Subject: Scan question
> >> Can I change the SCAN field at runtime?
> >> E.g. inside my own custom record.
> >> Some devices normally needs only be scanned say once a sec
> or every 5
> >> secs. But then when you change the value you want the scanned
> >> faster at
> >> say 0.2 secs.
Re: Scan question John Sinclair
Prev: Re: Scan question Ralph Lange
Next: ai, soft channel, and breakpoint table John Dobbins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Scan question Emmanuel Mayssat
