1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: ai, soft channel, and breakpoint table
To: EPICS Tech-Talk <[email protected]>
Date: Mon, 16 Jul 2007 08:42:50 -0400
Is it possible to use a breakpoint table in an ai record to convert the output of another ai record (without loss of resolution)?
I have an ai record for which device support retrieves a floating point value from hardware and puts it directly into the VAL field.
I would like to use a breakpoint table in a second ai record to convert the reading of the first record - which (as I understand it) would require me to use a "Raw Soft Channel". Will a "Raw Soft Channel" ai record, in reading a value into RVAL, convert it to an integer (with a loss of resolution)?
Alternatives?
Thanks and regards,
John Dobbins
Lab for Elementary Particle Physics
Cornell University
RE: ai, soft channel, and breakpoint table Allison, Stephanie
Re: ai, soft channel, and breakpoint table Martin L. Smith
Prev: RE: Scan question Mark Rivers
Next: Re: Asyn 4.8 compile error with Linux GPIB Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Asyn 4.8 compile error with Linux GPIB Andrew Johnson
Next: RE: ai, soft channel, and breakpoint table Allison, Stephanie
