1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Asyn 4.8 compile error with Linux GPIB
To: Jiro Fujita <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Mon, 16 Jul 2007 14:34:26 -0500
Jiro Fujita wrote:
I have been trying to compile Asyn 4-8 with Linux GPIB support.  I am
using a National Instrument PCI GPIB card with EPICS Base 3.14.9 on a
Scientific Linux 4.2.  The card is recognized by the system.  I have
installed linux-gpib-3.2.09.
When I try to compile Asyn, I get the following error:
I looked for libgpib.a, but I don't see it on my machine.  Instead, I
find libgpib.la.  Does anybody have an idea how to fix this??
I have no experience with your specific problem, but I do know that a libXXX.la file is usually a version of a library created by an application that uses GNU libtool before it is installed using 'make install'.
Did you compile the National Instruments libgpib.la program yourself? If so, try doing a 'make install' in that directory which in my experience will cause the appropriate libgpib.a file to be created and installed in the appropriate location. If you can't do that because you don't have write access to the target directory you might need to re-run the ./configure program in the GPIB build area specifying a --prefix=/path/to/somewhere.
As an alternative, you can try looking for a hidden directory in the same directory as the libgpib.la file which I think will contain the actual libgpib.a file that you're looking for.
HTH,
- Andrew
The right to be heard does not automatically include
the right to be taken seriously. -- Hubert H. Humphrey
Re: Asyn 4.8 compile error with Linux GPIB Jiro Fujita
Prev: ai, soft channel, and breakpoint table John Dobbins
Next: Re: Asyn 4.8 compile error with Linux GPIB Jiro Fujita
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Asyn 4.8 compile error with Linux GPIB Jiro Fujita
