1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Asyn 4.8 compile error with Linux GPIB
To: "Andrew Johnson" <[email protected]>, "EPICS tech-talk" <[email protected]>
Date: Mon, 16 Jul 2007 16:03:28 -0500
I originally installed the driver from National Instrument.  Then,
when I realized that it appears that Asyn wants to use Linux GPIB
package library, according to asynDriver documentation
(http://www.aps.anl.gov/epics/modules/soft/asyn/R4-8/asynDriver.html#Linux-gpib),
I downloaded linux-gpib-3.2.09, did make and make install.
I don't see libgpib.a anywhere on my machine: not in the same
directory as libgpib.la nor where I compiled.
It appears that at some point, libgpib.a has gotten renamed to
libgpib.la in Linux GPIB package library.  There has been some
references of libgpib.a in older Linux GPIB package library (at least
old version, I see a reference of it).
I have not tracked down far enough to see where the reference to
libgpib.a is made in Asyn (the assumption is that I need to change a
few lines somewhere).
On 7/16/07, Andrew Johnson <[email protected]> wrote:
Jiro Fujita wrote:
> I have been trying to compile Asyn 4-8 with Linux GPIB support.  I am
> using a National Instrument PCI GPIB card with EPICS Base 3.14.9 on a
> Scientific Linux 4.2.  The card is recognized by the system.  I have
> installed linux-gpib-3.2.09.
> When I try to compile Asyn, I get the following error:
> I looked for libgpib.a, but I don't see it on my machine.  Instead, I
> find libgpib.la.  Does anybody have an idea how to fix this??
I have no experience with your specific problem, but I do know that a
libXXX.la file is usually a version of a library created by an
application that uses GNU libtool before it is installed using 'make
install'.
Did you compile the National Instruments libgpib.la program yourself?
If so, try doing a 'make install' in that directory which in my
experience will cause the appropriate libgpib.a file to be created and
installed in the appropriate location.  If you can't do that because you
don't have write access to the target directory you might need to re-run
the ./configure program in the GPIB build area specifying a
--prefix=/path/to/somewhere.
As an alternative, you can try looking for a hidden directory in the
same directory as the libgpib.la file which I think will contain the
actual libgpib.a file that you're looking for.
HTH,
- Andrew
The right to be heard does not automatically include
the right to be taken seriously. -- Hubert H. Humphrey
RE: Asyn 4.8 compile error with Linux GPIB Mark Rivers
Re: Asyn 4.8 compile error with Linux GPIB Guy Jennings
Asyn 4.8 compile error with Linux GPIB Jiro Fujita
Re: Asyn 4.8 compile error with Linux GPIB Andrew Johnson
Prev: Re: Asyn 4.8 compile error with Linux GPIB Andrew Johnson
Next: RE: Asyn 4.8 compile error with Linux GPIB Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
