> I have not tracked down far enough to see where the reference to
> libgpib.a is made in Asyn (the assumption is that I need to change a
> few lines somewhere).
The only reference is here, in asyn/Makefile
ifeq ($(LINUX_GPIB),YES)
SRC_DIRS += $(ASYN)/linuxGpib
asyn_SRCS_Linux += drvLinuxGpib.c
DBD += drvLinuxGpib.dbd
asyn_LIBS += gpib
endif
You see that it does not refer explicitly to libgpib.a, it just refers to gpib. The lib and .a are implicit. I think it may be hard to get make to look for the .la file, even if it would work. From Andrew's message it seems like you need to find how to turn the .la file in a .a file.
Sent: Mon 7/16/2007 4:03 PM
To: Andrew Johnson; EPICS tech-talk
Subject: Re: Asyn 4.8 compile error with Linux GPIB
I originally installed the driver from National Instrument. Then,
when I realized that it appears that Asyn wants to use Linux GPIB
package library, according to asynDriver documentation
(http://www.aps.anl.gov/epics/modules/soft/asyn/R4-8/asynDriver.html#Linux-gpib),
I downloaded linux-gpib-3.2.09, did make and make install.
I don't see libgpib.a anywhere on my machine: not in the same
directory as libgpib.la nor where I compiled.
It appears that at some point, libgpib.a has gotten renamed to
libgpib.la in Linux GPIB package library. There has been some
references of libgpib.a in older Linux GPIB package library (at least
old version, I see a reference of it).
On 7/16/07, Andrew Johnson <[email protected]> wrote:
> Hi,
> Jiro Fujita wrote:
> > I have been trying to compile Asyn 4-8 with Linux GPIB support. I am
> > using a National Instrument PCI GPIB card with EPICS Base 3.14.9 on a
> > Scientific Linux 4.2. The card is recognized by the system. I have
> > installed linux-gpib-3.2.09.
> > When I try to compile Asyn, I get the following error:
> > I looked for libgpib.a, but I don't see it on my machine. Instead, I
> > find libgpib.la. Does anybody have an idea how to fix this??
> I have no experience with your specific problem, but I do know that a
> libXXX.la file is usually a version of a library created by an
> application that uses GNU libtool before it is installed using 'make
> install'.
> Did you compile the National Instruments libgpib.la program yourself?
> If so, try doing a 'make install' in that directory which in my
> experience will cause the appropriate libgpib.a file to be created and
> installed in the appropriate location. If you can't do that because you
> don't have write access to the target directory you might need to re-run
> the ./configure program in the GPIB build area specifying a
> --prefix=/path/to/somewhere.
> As an alternative, you can try looking for a hidden directory in the
> same directory as the libgpib.la file which I think will contain the
> actual libgpib.a file that you're looking for.
> HTH,
> - Andrew
> The right to be heard does not automatically include
> the right to be taken seriously. -- Hubert H. Humphrey
- Asyn 4.8 compile error with Linux GPIB Jiro Fujita
- Re: Asyn 4.8 compile error with Linux GPIB Andrew Johnson
- Re: Asyn 4.8 compile error with Linux GPIB Jiro Fujita
Re: Asyn 4.8 compile error with Linux GPIB Guy Jennings
<2007>
2025
2026
<2007>
2025
2026
