1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Asyn 4.8 compile error with Linux GPIB
Cc: EPICS tech-talk <[email protected]>
Date: Tue, 17 Jul 2007 16:23:19 -0500
Hi Mark,
Mark Rivers wrote:
So it seems to me that SYS_LIBS IS the appropriate option for libgpib.a, because that normally would reside in one of the linkers default library search paths.
My Fedora Core 6 installation doesn't list /usr/local/lib in /etc/ld.so.conf (I think the OP was using FC-6 too IIRC).
uranus% cat /etc/ld.so.conf
include ld.so.conf.d/*.conf
uranus% cat /etc/ld.so.conf.d/*
/usr/lib/atlas
/usr/lib/octave-2.9.9
/usr/lib/qt-3.3/lib
SYS_LIBS does seem reasonable, but if you're going to do that then the asyn documentation should explain that to use the NI libgpib.so library the user may have to add an entry to /etc/ld.so.conf or create a new file in /etc/ld.so.conf.d to include the appropriate directory in the linker's default search path.
- Andrew
The right to be heard does not automatically include
the right to be taken seriously. -- Hubert H. Humphrey
RE: Asyn 4.8 compile error with Linux GPIB Mark Rivers
Prev: RE: Asyn 4.8 compile error with Linux GPIB Mark Rivers
Next: Re: IPac driver organisation Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: ai, soft channel, and breakpoint table John Dobbins
