1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: RE: Asyn 4.8 compile error with Linux GPIB
To: "Andrew Johnson" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Tue, 17 Jul 2007 11:47:56 -0500
The Application Developer's Guide does not explain the difference
between asyn_LIBS and asyn_SYS_LIBS, except for the order in which they
are passed to the linker.  What is the difference?  I have always used
SYS_LIBS for libraries that are not in the EPICS directories.  I think
one difference is that when building a static application that shareable
versions of SYS_LIBS are still used, while all non SYS_LIBS libraries
are statically built into the binary, right?  Is this documented
anywhere?
> -----Original Message-----
> From: Andrew Johnson [mailto:[email protected]]
> Sent: Tuesday, July 17, 2007 10:49 AM
> To: Mark Rivers
> Cc: Jiro Fujita; EPICS tech-talk
> Subject: Re: RE: Asyn 4.8 compile error with Linux GPIB
> Hi Mark,
> > The line
> > asyn_LIBS += gpib
> > tells the EPICS build system to look for libgpib.a in the EPICS
> > directories.  This does not seem to be correct, that is a system
> > library, not an EPICS library.  So I think that line should be
> No, setting asyn_LIBS like that tells the build system to
> link the asyn binary with libgpib (it results in the link
> line having -lgpib added to it). If libgpib is not being
> found you can explicitly tell the build system where it is by
> setting the gpib_DIR variable in the Makefile.  Alternatively
> and more generally you can tell the linker to look in
> /usr/local/lib automatically by listing that directory in
> /etc/ld.so.conf or by creating a file in /etc/ld.so.com.d
> with the appropriate setting.
> > Note, I think that LD_LIBRARY_PATH is used only at run-time to find
> > .so files, not when building applications, so I would not expect it
> > to work.
> Sorry, but you're wrong there too; having LD_LIBRARY_PATH set
> at build-time is actually frowned upon nowadays because if
> it's set at link time its value will be saved in the binary
> and the path re-used at runtime, which is contrary to how
> most Linux package management systems like to work (they
> build in a different location to their final runtime
> location, so their link-time paths will not be valid at runtime).
> > I don't think you have explained how libgpib.a got in the asyn
> > tree, if it really is there.
> I agree, I think that file should be deleted.
> - Andrew
Re: Asyn 4.8 compile error with Linux GPIB Janet Anderson
Re: RE: Asyn 4.8 compile error with Linux GPIB Andrew Johnson
Prev: Re: RE: Asyn 4.8 compile error with Linux GPIB Andrew Johnson
Next: IPac driver organisation Doug Murray
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Asyn 4.8 compile error with Linux GPIB Janet Anderson
