Title: IPac driver organisation
Hi Andrew, I’ve noticed the IPac directory contains support for a number of carrier cards. Would it be possible to add drivers for:
xycom9660
acromag9670
hytec8002
We use these at SLAC, and we’re using RTEMS so we’ve had to OSI-ify these packages.
Also, I see drivers for a few IP cards in that directory, such as CANbus and an Octal UART card. Is the idea that new IP drivers be placed in this directory as well?
On a related note, the GPIB IP card (IP488) is located in the Asyn directory. Should IP modules be put under Asyn?
Regards
-doug
- Re: IPac driver organisation Andrew Johnson
RE: RE: Asyn 4.8 compile error with Linux GPIB Mark Rivers
Re: Asyn 4.8 compile error with Linux GPIB Janet Anderson
<2007>
2025
2026
Re: MEDM enum not displaying correctly? Benjamin Franksen
<2007>
2025
2026
ANJ, 10 Nov 2011 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
