On Tuesday 17 July 2007 09:14, Heinrich du Toit wrote:
> I have a custom record with a ENUM field.
> This field has 100's of possible options.
> My get_enum_str function is implemented.
> But I don't have get_enum_strs or put_enum_str cause this is a read-only
> field and MEDM can only get 16 options so it wouldn't matter.
Yes that's one of the static size limits in EPICS. Unfortunately it is also
hardcoded into CA which is yet another reason for your problems...
> Now if I setup a text monitor for the field I only get the
> decimal(integer) value?
> If I use the PV Info option it says Value = the string I want.
> How do I get medm to display this string in the text monitor?
MEDM, like many (but not all) CA client apps, requests data in the CA
server's "native" type (to minimize IOC and network load) which in your
case would be enum which is represented as a 16 bit integral value.
Conversion to a string needs the table that associates numbers with
strings, but CA allows only 16 values here. Bummer.
The work-around for the CA limit is to create a stringin record with INP set
to monitor the enum field and then reference this stringin in your MEDM
display. This works because the stringin record requests the data as
string.
This, however, is not the end of the story. Next, you need to take care that
your record support is able to correctly answer a string request for the
field in question. As you found out it is not possible to use the built-in
conversion support because it is limited, albeit to 30 items, not 16, at
least since 3.14.
Anyway, it should be possible to work around this issue, too, by making the
field special(SPC_DBADDR) in the dbd and adding an appropriate cvt_dbaddr
method to the record support. This method is called prior to the request
and can change all the values of the DB_ADDR that it receives. So, whenever
you get a request of type DBR_STRING, just change the field pointer of the
structure to point to the correct string in you string table.
If you think all this is far from being obvious, well I couldn't agree more.
Cheers
Ben
- Re: MEDM enum not displaying correctly? Benjamin Franksen
- MEDM enum not displaying correctly? Heinrich du Toit
Re: Asyn 4.8 compile error with Linux GPIB Janet Anderson
RE: Asyn 4.8 compile error with Linux GPIB Mark Rivers
<2007>
2025
2026
<2007>
2025
2026
