1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: MEDM enum not displaying correctly?
To: [email protected]
Date: Wed, 18 Jul 2007 01:18:39 +0200
On Tuesday 17 July 2007 22:35, Benjamin Franksen wrote:
> Anyway, it should be possible to work around this issue, too, by making
> the field special(SPC_DBADDR) in the dbd and adding an appropriate
> cvt_dbaddr method to the record support. This method is called prior to
> the request and can change all the values of the DB_ADDR that it
> receives. So, whenever you get a request of type DBR_STRING, just change
> the field pointer of the structure to point to the correct string in you
> string table.
Oh, and you must of course also change the field type in the DBADDR struct
to DBF_STRING, otherwise your string data gets interpreted as a DBF_ENUM
which would be, ahem, bad.
Cheers
Ben
Re: MEDM enum not displaying correctly? Benjamin Franksen
MEDM enum not displaying correctly? Heinrich du Toit
Prev: Re: IPac driver organisation Andrew Johnson
Next: RE: ai, soft channel, and breakpoint table Allison, Stephanie
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: MEDM enum not displaying correctly? Benjamin Franksen
Next: Re: MEDM enum not displaying correctly? Benjamin Franksen
