1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: correlations application
To: Christopher Larrieu <[email protected]>
Cc: [email protected]
Date: Mon, 30 Jul 2007 17:19:09 -0500
Mark Rivers wrote:
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Christopher Larrieu
Sent: Monday, July 30, 2007 12:51 PM
To: [email protected]
Subject: correlations application
I've been tasked with developing a new correlation application to replace
the storied Correlation Plots from the old SLC control system.
My intent was to develop an eclipse-based java app to accomplish this.
I'll guess the easiest and most widely useful choice would be to develop an eclipse-based java app that programs sscan records and displays their data.
However, Earnest Williams and Stephanie Allison suggested that I should look
into sscan and SynApps.
While these tools do seem feature-rich, they don't provide all of the things
that we want. So my questions are
(1) can they provide the functionality we want?
(2) do we need the functionality that we think we want?
The main issues:
(a) user-extensibility
We want our physicists and other users easily to define steps, measures, and step functions using tools they are familiar
with, like Matlab.
The sscan record can certainly do that.  It can do conventional linear
scans (start, stop, step), and also table-mode where a table of target
positions is downloaded.  We use IDL to generate tables for EXAFS, where
the step sizes are different in different parts of the scan (pre-edge,
XANES, EXAFS).
If your users are familiar with EPICS, and particularly with using EPICS' run-time programmable records, such as the *calcout records,
they can do a fair amount of scan programming right in the IOC, and
other software in the IOC can easily control the resulting system.
(b) beam synchronous data acquisition
We need to use our specially developed beam synchronous data acquisition system to acquire pulse-synchronous data. How can the
sscan
record support this?
I think you can do it with a detector trigger, but need more information
to be sure.
Me too.
(c) concurrent use
Can one perform multiple scans concurrently with the sscan record, or must one pre-create multiple instances of the record to
achieve such?
What do you mean by "concurrently".  Really at the same time (then you
need multiple sscan records) or in quick succession (then one sscan
record can be used and the parameters changed from the client).  Note
that sscan records can be nested to generated N-dimensional scans.
I don't understand what's meant here either, but I'll guess you need to preload. Note that a sscan record doesn't take up all that much memory until it's actually used, so you can load *lots* of them in modern processors, such as the 5100. (Only the positioner arrays are allocated at init time.) Also note that scan nesting is programmable at run time, so you don't need to load a bunch of 1D scans, and a separate bunch of 2D scans.
(d) data types
Can this system retrieve data of types other than simple numbers?
Yes, it can retrieve arrays.  The detector readback fields are doubles,
so it cannot handle strings, for example.
(e) design philosophy
Is it a good idea to put this sort of functionality in an IOC? It seems sort of limiting to me. Why do it? Is it a matter of
using
the tools at hand, or are there more compelling reasons that I don't
see,
being mostly unfamiliar with IOC level applications?
It was designed this way for performance.  If all of the things being
scanned are in that IOC (which they do not have to be) then scans of
hundreds of points per second can be achieved.  This is difficult to do
over the network from a client.
Now that we have soft IOCs, if you don't have strict performance
requirements, then you don't need to put the scans in the real-time
(RTEMS, vxWorks) IOC, but rather run them on a workstation IOC (Linux,
Windows, etc.)
One very nice thing about IOC-level applications is that they are automatically middleware. Thus, they can drive lower-level software, or be driven by higher-level software, or both. So an IOC-level application can easily become a building block in someone else's new design. For example, someone might want to implement automated alignment, using data from a series of scans. The job would be much easier if one could simply reuse existing scan software.
If you implement scans in a client outside of an IOC, you can certainly engineer this sort of capability in, but you have to do it on purpose, it's not a bit easy, and you don't get as much help from EPICS' core (e.g., Channel Access, putNotify, automatic data-type conversion, access security, and all the other nice things we've come to take for granted in EPICS) or from other EPICS support (e.g., save/restore, stripTool, MEDM, probe, archivers).
If scans are implemented in an IOC, then "everybody" already knows how to talk to them, and can do it easily from EPICS, IDL, Python, Java, Igor, Matlab, SNL, etc.
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls & Data Acquisition Group
Advanced Photon Source, Argonne National Lab.
Re: correlations application Pete R. Jemian
Re: correlations application Christopher Larrieu
RE: correlations application Mark Rivers
Prev: RE: correlations application Mark Rivers
Next: Re: correlations application Pete R. Jemian
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
