1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Possible Bug in 3.14.9 Access Security on mv2100
To: EPICS Tech Talk <[email protected]>
Date: Wed, 08 Aug 2007 13:53:28 +0200
Hello everyone -
trying to switch over the first set of production IOCs to 3.14.9 we are seeing a perfectly strange behaviour of Access Security on mv2100 (ppc603) IOCs:
Environment: 3.14.9 (architecture vxWorks-ppc603), exampleApp from base, Tornado 2.0.2 (SNS cross compiler), Linux host.
Having sucessfully loaded a minimal access security file
 ASG(DEFAULT) {
   RULE(1,WRITE)
the mv2100 IOC does not always grant permissions to CA clients for all its channels.
Calling asDump() on the IOC prints the correct database (as expected).
The caget, caput, cainfo clients report no read and no write access.
On the other hand, the camonitor clients works. (!!!)
This strange behaviour does not change by introducing HAGs and UAGs that should explicitly allow access for the test client.
If asSetFilename() is commented out, Access security is not started (asDump() yields nothing), all CA clients get read and write access, everything works.
When doing the same tests against a Linux soft IOC, everything works as expected.
Under 3.14.8.2 in the same setup, everything works as expected on all platforms. This behaviour seems new for 3.14.9.
Does anyone have similar experiences?
Is anyone sucessfully using Access Security in a similar environment?
Any idea how to proceed? (We use CA Put Logging, so we have to have Access Security running on the IOCs.)
Clueless,
Ralph
Re: Possible Bug in 3.14.9 Access Security on mv2100 Steven Hartman
Prev: Re: Enabling drvLinuxGpib (linux-gpib) Gasper Jansa
Next: Re: Possible Bug in 3.14.9 Access Security on mv2100 Steven Hartman
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: ArchiveDataServer - signals appear to stop changing after run of update_server cron job Devin Bougie
