Has anyone run across a problem with StripTool 2.5.12.0 having trouble
getting the Y range correct on the graph?
When I specify a PV in the controls dialog the Min and Max values displayed
there do not match the Y-min and Y-max values on the graph. The Y axis on
the graph is always 0 to 100. Even if I modify Min and Max in the Curves tab
of the controls dialog the graph will not change the Y axis range from 0 to
100.
The following error is written to the console with the same period as the
graph redraw interval:
==== StripTool Xt Warning Handler ====
Warning: Axis: minVal is greater than or equal to maxVal
I see this problem when I compile it under OpenSuse 10.1, Linux 2.6, Base
3.14.9 on a 64-bit machine. I've compiled the same version of StripTool on
another machine (RedHat 9, Linux 2.4, Base 3.14.8.2 on a 32-bit machine) and
the graphs are drawn fine.
Damien Lynch
Accelerator IT Systems Engineer
Australian Nuclear Science and Technology Organisation
PMB 1, Menai NSW 2234
T 02 9717 3662
F +61 2 9717 3257
www.ansto.gov.au
Important: This transmission is intended only for the use of the addressee.
It is confidential and may contain privileged information or copyright
material. If you are not the intended recipient, any use or further
disclosure of this communication is strictly forbidden. If you have received
this transmission in error, please notify me immediately by telephone and
delete all copies of this transmission as well as any attachments.
Re: Possible Bug in 3.14.9 Access Security on mv2100 Ralph Lange
1785-ENET Device Support James B. Stevens
<2007>
2025
2026
Re: Possible Bug in 3.14.9 Access Security on mv2100 Dirk Zimoch
<2007>
2025
2026
