1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: rpath compiling?
To: Heinrich du Toit <[email protected]>
Cc: TechTalk EPICS <[email protected]>
Date: Fri, 17 Aug 2007 14:21:02 +0200
Hi Heinrich,
Unset RUNTIME_LDFLAGS in your Makefile or CONFIG.*. But then you must setup LD_LIBRARY_PATH properly or use ldconfig.
However, what I do is to set INSTALL_LOCATION of base to a specific installation directory, e.g. /usr/local/epics/base-3.14.8. This will be used for rpath, not the source directory! Then I build base, pack the installation directory and install it to all PCs.
However, for extensions like medm, I set EPICS_BASE to /usr/local/epics/base, which is a symbolic link to the current base version.
> ls -l /usr/local/epics
total 40
lrwxrwxrwx    1 root     root    11 Jun  1 02:36 base -> base-3.14.8
drwxrwxr-x    9 root     sls   4096 Apr 12  2006 base-3.13.10
drwxr-xr-x   10 root     sls   4096 Apr 12  2006 base-3.13.2
drwxr-xr-x   10 root     sls   4096 Apr 12  2006 base-3.13.9
drwxrwxr-x   11 root     sls   4096 Dec 14  2006 base-3.14.7
drwxrwxr-x   11 root     sls   4096 Jul 17 13:23 base-3.14.8
drwxrwxr-x   11 root     sls   4096 May 16 17:44 base-3.14.9
drwxrwxr-x   11 root     sls   4096 Nov 23  2006 base-3.14.CVS
drwxrwxr-x   12 root     sls   4096 Nov 17  2006 extensions
lrwxrwxrwx    1 root     sls     10 Aug 17  2006 seq -> seq-2.0.10
drwxrwxr-x    7 root     sls   4096 Jun 21 15:02 seq-2.0.10
drwxrwxr-x    3 root     sls   4096 Apr  3  2006 seq-2.0.8
Thus, when I change the symbolic link to a new version of base, all client programs will automatically use the new version.
Dirk
Heinrich du Toit wrote:
Hi
I'm trying to built an ubuntu package for EPICS :)
Just so that I don't have to compile the thing on every client out
there. - Some machines don't really need gcc and all that development
stuff
Anyways.
I'm having a bit of trouble with the way EPICS links to it's own .so
files.
(linux-x86)
It seems that the compile thing sets --rpath in the linker.
This way it links to a specific directory.
Problem is that this directory is not the same when built and installed.
So I would like to have it built without rpath set. Then install the .so files to /usr/lib And then normal ld.so stuff in linux can link it up.
My question is - how do I get EPICS to not link to a specific directory?
This seems like a chicken-egg problem..
As I want to compile the things linked to libraries that will only be
installed later. :(
Any help will be appreciated
-Heinrich
-- Dr. Dirk Zimoch Paul Scherrer Institut, WBGB/006 5232 Villigen PSI, Switzerland Phone +41 56 310 5182
rpath compiling? Heinrich du Toit
Prev: rpath compiling? Heinrich du Toit
Next: Re: Possible Bug in 3.14.9 Access Security on mv2100 Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: rpath compiling? Adams, Billy R. (LARC-D401B)[RAYTHEON TECHNICAL SERVICES CO]
