1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Possible Bug in 3.14.9 Access Security on mv2100
To: Dirk Zimoch <[email protected]>
Cc: EPICS Tech Talk <[email protected]>, Ralph Lange <[email protected]>
Date: Fri, 17 Aug 2007 09:06:50 -0400
On Aug 17, 2007, at 08:39 , Dirk Zimoch wrote:
Ralph,
that's probably not the only CA problem in 3.14.9.
In May, I repored a bug to the Mantis bugtracker which has not even been assigned until now. (Maybe posting it to tech-talk helps.)
Summary long integer values are corruped in R3.14.9
Description
When writing integer values with a CA client (e.g. medm) to a long integer channel (e.g. longout record), the upper bytes get corrupted. The lower 2 bytes are OK.
I can't see the error when the client is caput from base.
Client and IOC run on a linux-x86 machine.
The problem is new in 3.14.9.
Could that be related to this byte swapping issue in the known problems: "G++ version 3.2.3 Jeff Hill reports the following:
During testing of R3.14.9 I see a bug showing up only in optimized builds on Linux using g++ 3.2.3 that I don't see with other compilers. This bug appears to be related to failure of this particular compiler to follow the strict alias rules specified in the standard when optimizing the byte swapping templates installed for R3.14.9.
Problems
Red hat Linux g++ 3.2.3 when -O3 is specified
-Kay
Possible Bug in 3.14.9 Access Security on mv2100 Ralph Lange
Re: Possible Bug in 3.14.9 Access Security on mv2100 Steven Hartman
Re: Possible Bug in 3.14.9 Access Security on mv2100 Ralph Lange
Re: Possible Bug in 3.14.9 Access Security on mv2100 Dirk Zimoch
Prev: RE: rpath compiling? Adams, Billy R. (LARC-D401B)[RAYTHEON TECHNICAL SERVICES CO]
Next: Re: Possible Bug in 3.14.9 Access Security on mv2100 Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Possible Bug in 3.14.9 Access Security on mv2100 Dirk Zimoch
