1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: asyn 4.8 problem
To: "Robert Emery" <[email protected]>, <[email protected]>
Date: Wed, 22 Aug 2007 12:29:25 -0500
Rob,
We recently had a report from Dirk Zimich at PSI that VXI11 was not
working with asyn R4-8.  But he was upgrading from EPICS R3.13, not an
earlier version of asyn.  So your report is very useful, since you say
it worked in asyn R4-5.
Can you send the complete output when your IOC starts?
Can you set the asynTraceMask on that asyn port so that you get full
debugging information?
Also, I suspect that the problem may be coming from the code that was
added in asyn R4-6 to automatically queue a connect request (call to
pasynCommon->connect) when a call to pasynManager->connectDevice is done
for a port with the attributes autoConnect=Yes and isConnected=No.
Can you please try disabling this code with the following change that
comments out the call to pasynCommon->connect() and letting me know if
it fixes the problem?
corvette> cvs diff -rR4-8 asynManager.c
Index: asynManager.c
RCS file:
/net/phoebus/epicsmgr/cvsroot/epics/modules/soft/asyn/asyn/asynDriver/as
ynManager.c,v
retrieving revision 1.93
diff -u -r1.93 asynManager.c
--- asynManager.c       28 Apr 2007 21:19:58 -0000      1.93
+++ asynManager.c       22 Aug 2007 17:25:32 -0000
@@ -1185,6 +1185,7 @@
     pasynCommon = (asynCommon *)pasynInterface->pinterface;
     commonPvt   = pasynInterface->drvPvt;
     status = pasynCommon->connect(commonPvt, pasynUser);
     if (status != asynSuccess) {
         asynPrint(pasynUser, ASYN_TRACE_ERROR,
@@ -1192,6 +1193,7 @@
                   portName, pasynUser->errorMessage);
         goto cleanup;
     cleanup:
     status = pasynManager->freeAsynUser(pasynUser);
> -----Original Message-----
> From: [email protected]
> [mailto:[email protected]] On Behalf Of Robert Emery
> Sent: Wednesday, August 22, 2007 11:25 AM
> To: [email protected]
> Subject: asyn 4.8 problem
> I have recently upgraded from asyn 4.5 to 4.8 and am seeing the
> following error messages whereas I didn't have them with 4.5:
> Starting iocInit
> ###  EPICS IOC CORE built on Oct  9 2006
> ###  EPICS R3.14.8.2 $R3-14-8-2$ $2006/01/06 15:55:13$
> 2007/08/22 09:01:13.319 gpib0,1 vxiCreateDeviceLink RPC error : RPC:
> Unable to receive; errno = Connection reset by peer
> 2007/08/22 09:01:13.319 CoilA vxiCreateDevLink failed for addr 1
> 2007/08/22 09:01:13.319 asynManager::asynConnectCallback, port CoilA
> error calling asynCommon->connect
> Unable to send; errno = Broken pipe
> I am using this to control equipment on GPIB via an Agilent E5810
> Ethernet/GPIB bridge.
> Any ideas?
> Thanks
> Rob Emery
> UW Medical Center
Re: asyn 4.8 problem Robert Emery
Prev: bug in Red Hat Linux g++ 3.2.3 Jeff Hill
Next: Port of EPICS 3.14.9 to ETRAX CRIS architecture - Strange Data Peter Zumbruch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: asyn 4.8 problem Robert Emery
Next: Re: asyn 4.8 problem Robert Emery
